  1. #17
    Thanks for the advice guys, will check this out. Little more progress made today:
    Ground down all the welds slightly and fully at any mating faces (does this weaken the welds?):
    Attachment 17865Attachment 17866
    Welds seemed to start getting a little bit neater:
    Attachment 17864Attachment 17867
    I am running on a small tank of CO2 which as per your comments isn't the best as its already ran out I noticed it a long time after my welds started getting worse and thought it was just me welding horribly (although that would have been part of the reason )
    Attachment 17869
    The empty tank meant I was only able to get both sides done this week:
    Attachment 17868
    Will be back on it next weekend and hopefully have the full frame/gantry welded
  1. BUILD LOG: First Build 5 x 12 Steel Frame CNC router
    By Scott Damman in forum DIY Router Build Logs
    Last Post: 18-01-2017, 06:36 PM
  2. BUILD LOG: New Build, Aluminium Frame Router/Mill
    By Davek0974 in forum DIY Router Build Logs
    Last Post: 31-08-2016, 05:28 PM
  3. BUILD LOG: Steel frame cnc router design/build
  4. BUILD LOG: First steel diy CNC router build
  5. BUILD LOG: 7' X 4' Steel frame build
