  1. #17
    Hi guys, been a while as life seems to keep getting in the way!! Some progress so far:
    Had the frame and gantry welded up and cut back down over 3 times in attempt of getting it all lined up with minimal distortion, but finally got there in the end! (I hope)
    Attachment 18164Attachment 18165Attachment 18166
    Aluminium also came in, so started work on the Z-Axis. Think I slipped a bit with the blue...:
    Attachment 18162Attachment 18163
    Think its now finally time to start looking into the epoxy leveling on the X axis, only thing is getting it up to temperature (I think Dean mentioned 20C for 3 days at least). Other than waiting for the sun to come out (if ever), I think my only other choice is to stick it in the shed with an electric heater. What do you guys think?
  1. BUILD LOG: First Build 5 x 12 Steel Frame CNC router
    By Scott Damman in forum DIY Router Build Logs
    Last Post: 18-01-2017, 06:36 PM
  2. BUILD LOG: New Build, Aluminium Frame Router/Mill
    By Davek0974 in forum DIY Router Build Logs
    Last Post: 31-08-2016, 05:28 PM
  3. BUILD LOG: Steel frame cnc router design/build
  4. BUILD LOG: First steel diy CNC router build
  5. BUILD LOG: 7' X 4' Steel frame build
