05-11-2016 #19
Will look at this properly for you later but see one thing I'd change. Use contactor rather than relay contact for turning on transformer. Still use relay for safety but have turn it on contacter which is better suited to high current.
Also what kind of limit switch are you using.? On quick look if Proximity then think you have them wired wrong. If Prox what type NPN or PNP.?
BUILD LOG: First Build 5 x 12 Steel Frame CNC router
By Scott Damman in forum DIY Router Build LogsReplies: 104Last Post: 18-01-2017, 06:36 PM -
BUILD LOG: New Build, Aluminium Frame Router/Mill
By Davek0974 in forum DIY Router Build LogsReplies: 101Last Post: 31-08-2016, 05:28 PM -
By Ricardoco in forum DIY Router Build LogsReplies: 6Last Post: 28-10-2012, 06:02 PM
