    Dibond is an aluminium sandwich with a Polyethylene core. The burrs you are looking to avoid are therefore aluminium - I bet it isn't a nice free machining variety either. The left spiral will push the burr from the upper surface downwards. I'm not sure how the reverse will work on the lower edge unless you can machine an offset to the profile - 0.1mm might do for example - to stop the second tool from rubbing the first, finished cut. It's CNC after all, and a CNC control should manage a profile offset.
    Do you have the opportunity to have a rigid sacrificial surface beneath the work piece? Are the edges supported well enough to be stiff and not flex in machining? Reply #6 points out the pitfalls accurately. Are your profiles much smaller than the raw material? Can you use tabs to stabilise the profile whilst clamping on the waste?
    One strategy that may help is to use fewer flutes - single flute cutters are good for plastic, I'm not sure about sticky aluminium. Also to avoid excessive spiral angles - the longer the tool edge in contact with the work piece, the more friction raises the temperature and melts the local area, pushing a bigger burr as a result. Straight flutes have the lowest contact friction. High spirals tend to pump swarf along the tool - the burr tends to follow.
    Can you get a good air blow onto the tool? Keeping things cool won't stop burrs but may reduce them, and it will reduce the chance for chips to link up and rejoin the cut.
    Good luck.
    D
    Dibond can be cut in various ways but the bits that i like are 2 -3 flute straight ones or 2 flute fishtail 30degree spiral upcut which leave a mirror finish, and the bits originally meant to cut Dibond are single flute as pointed earlier. I know of only 2 ways to cut it properly:
    -vacuum bed
    -stick ultra thin strong double sided tape at least at the important points. Not the one they sell at stores. Best tape for purpose is photographic double sided thin tape used to bond methacrylate to photography. Its sold on rolls and 50m is 150-200 euro, but if you ask some sign shop for a meter it would last you months. Final pass should be no more than 0.2mm deep and slow as the tape is a bitch. So tape should be applied on small squares of 2-3cm here and there. Stick square bigger than 10x10cm and you will never unglue it, its so strong
    Possibly you problems with finish are from sheet flapping. With a sharp bit and air blown at the bit , when well fixed, you can cut it with speed of spindle for wood and say 1/3rd down the speed, at one pass/when vacuum table/.
    Thanks for the contributions everyone.
    I ended up buying some 3mm up and downcut endmills from http://cnc-plus.de.
    Tried some some cuts on 3mm Dibond using a diy mdf vacuum bed and the results were great!.
    Thanks,
    James
  1. Group Buy - End Mills?
    By Tenson in forum Marketplace Discussion
    Last Post: 18-05-2012, 09:23 PM
  2. Carbide End Mills now available from shop-apt.co.uk
    By APT in forum Manufacturer News
    Last Post: 07-03-2012, 10:23 PM
  3. FOR SALE: End mills and Ball mills for sale......
    Last Post: 16-02-2011, 12:37 AM
  4. WANTED: Looking for used mills ?
    By Meldreth_Nick in forum Items Wanted
    Last Post: 20-09-2010, 01:31 PM
  5. axminster mills
    By richb77 in forum Milling Machines, Builds & Conversions
    Last Post: 22-10-2008, 05:02 PM
