Thread: 55 degree cutter
	08-06-2009 #1I want to use the spare parts from my x1 mill and need to cut some 55 degree dovetails but I have only seen 60 and 45 degree cutters are others available or will it be easier to cut with slitting saw etc.
 peter
	08-06-2009 #2One slight problem.
 If that's a 1 1/2" cutter then the shank is 3/4" or 7/8" judging from the picture.
 A tad on the big size for a MT2 collet on an X1 :heehee:
 Slitting saw or use a 45 degree cutter and do two passes, one at vertical and one at 10 degree tilt.
 .John S -
	08-06-2009 #3No I only have the x1 mill.
 I want to machine a new base si I can use my spare parts on my drilling machine as it would give me a x-y table.
 I may get that 55 degree cutter and turn the shank down to 1/2" dia.
 Cheaper than the £40 found on the net.
 peter
	08-06-2009 #4You won't turn the shank down it's solid HSS. John S -
	08-06-2009 #5I thought you could turn hss using carbide insert cutters, I'm sure I've done it before.
 Peter
	08-06-2009 #6Peter,
 I'll check in the morning to see what I have.
 I did have one reground once for a weird Taiwanese mortiser but I reckon it was 65 degrees.
 Anyway I'll still check and if I have one you can borrow it.John S -
  fly cutter advice pleaseBy luke11cnc in forum Tool & Tooling TechnologyReplies: 13Last Post: 07-12-2014, 01:38 PM
  Stepper controller to manually input a specific degreeBy Web Goblin in forum Motor Drivers & ControllersReplies: 11Last Post: 13-10-2013, 05:47 AM
  45 Degree and round-over bits?By Tenson in forum Tool & Tooling TechnologyReplies: 4Last Post: 05-05-2012, 04:13 PM
  Which Plasma Cutter to buy?By AndyG in forum General DiscussionReplies: 7Last Post: 02-12-2011, 09:34 AM
  cutter for MDFBy deannos in forum Tool & Tooling TechnologyReplies: 5Last Post: 16-10-2011, 09:33 PM
