Thread: 55 degree cutter
08-06-2009 #1
I want to use the spare parts from my x1 mill and need to cut some 55 degree dovetails but I have only seen 60 and 45 degree cutters are others available or will it be easier to cut with slitting saw etc.
peter
08-06-2009 #2
One slight problem.
If that's a 1 1/2" cutter then the shank is 3/4" or 7/8" judging from the picture.
A tad on the big size for a MT2 collet on an X1 :heehee:
Slitting saw or use a 45 degree cutter and do two passes, one at vertical and one at 10 degree tilt.
.John S -
08-06-2009 #3
No I only have the x1 mill.
I want to machine a new base si I can use my spare parts on my drilling machine as it would give me a x-y table.
I may get that 55 degree cutter and turn the shank down to 1/2" dia.
Cheaper than the £40 found on the net.
peter
08-06-2009 #4
You won't turn the shank down it's solid HSS.
John S -
08-06-2009 #5
I thought you could turn hss using carbide insert cutters, I'm sure I've done it before.
Peter
08-06-2009 #6
Peter,
I'll check in the morning to see what I have.
I did have one reground once for a weird Taiwanese mortiser but I reckon it was 65 degrees.
Anyway I'll still check and if I have one you can borrow it.John S -
fly cutter advice please
By luke11cnc in forum Tool & Tooling TechnologyReplies: 13Last Post: 07-12-2014, 01:38 PM -
Stepper controller to manually input a specific degree
By Web Goblin in forum Motor Drivers & ControllersReplies: 11Last Post: 13-10-2013, 05:47 AM -
45 Degree and round-over bits?
By Tenson in forum Tool & Tooling TechnologyReplies: 4Last Post: 05-05-2012, 04:13 PM -
Which Plasma Cutter to buy?
By AndyG in forum General DiscussionReplies: 7Last Post: 02-12-2011, 09:34 AM -
cutter for MDF
By deannos in forum Tool & Tooling TechnologyReplies: 5Last Post: 16-10-2011, 09:33 PM
