Thread: Power supply help
06-01-2016 #10
What you mean 4:1 if it's direct drive there's no ratio.? 59T direct drive means 185mm pitch.!!!
Anyway I strongly advise you to STOP and have re-think because your wasting your time on several fronts.
#1 No way can you move gantry that wide with one motor.
#2 Ratio of at least 5:1 will be needed with that size pinion.
#3 The drives are rubbish and even with 36V if they survive long enough they will run so badly and rough you'll struggle even with 2. This is because resonance will cripple them and turn them into horrible stalling nightmares. These cheap nasty drives have no way of dealing with resonance and with machine being all steel and not exactly HD the motors/drives will be affected.
#4 Looking at the Z axis unless your going to use for just Plasma then No way is that Z axis going to be upto cutting anything but foam. Certainly won't cut wood very well.
So again please don't take this wrong way I say it for your own sake and your wallets sake. You'll be wasting good money and time if you continue as you are.!
Power supply
By racerbear02 in forum Laser Machines & BuildingReplies: 0Last Post: 13-09-2015, 09:27 AM -
FOR SALE: power supply
By Web Goblin in forum Items For SaleReplies: 0Last Post: 14-09-2014, 03:19 PM -
Minimal-cost Power Supply Strategy - Repurpose Laptop Power Supplies
By LoveLearn in forum General ElectronicsReplies: 0Last Post: 25-01-2012, 09:29 PM -
FOR SALE: 50V 20A Power supply
By Jimmybristol in forum Items For SaleReplies: 8Last Post: 30-05-2011, 11:01 PM -
power supply
By hitmythumb in forum General ElectronicsReplies: 6Last Post: 21-06-2009, 10:27 AM
