Any advice would be greatly appreciated. I have just purchased a little cnc router for PCB work.
I have been trying different layout options while I wait for cables and connectors to turn up
There are three options that I can see and wondered if there are any issues with these, like electrical interference, heat concerns/ventilation or anything I may have missed.
Options 1 and 3 involved mounting the BOB onto acrylic and attaching this to the door panel.
The external case dimensions are 400mm x 300mm x 150mm but the removable steal base panel is 350 x 250 which is what I want to keep all the electrics on for ease of removal. All the connetors wil be mounted on the access panel on the side
Option 1 - and preferred option for me
Option 2
Option 3
07-01-2016 #2
My preference would be to have all parts in the case and not mounted to the door - Is there enough room to mount the powers supply on its side? Might give more room/options?
http://literature.rockwellautomation...m001_-en-p.pdf
This document makes an interesting read if you want to focus on handling electrical noise in a system (thanks EddyCurrent!)
JimLast edited by cncJim; 07-01-2016 at 03:45 PM.
The Following User Says Thank You to cncJim For This Useful Post:
07-01-2016 #3
Hi Jim,
Thanks for the quick reply.
I did look at mounting the power supply veritally but the lock on the door hits the top of the PSU on one side and on the other there is a bar which sticks proud of the door panel visible in the second picture next to the gounding wire, which also hits the top of the PSU meaning I have to move the PSU more to the centre of the case.
Besides, being lazy I wanted it flat so I can easily access the screw terinals
DaveLast edited by Bustercnc; 07-01-2016 at 04:41 PM. Reason: spelling mistake
07-01-2016 #4
Thanks Jim,
I just remeasured and the lip on the door clears the PSU by 1mm.
Looks like your suggestion is the better one and it does give me a lot more space. I origanlly wanted to keep the PSU flat for ease of access to the screw terminal but I can live with it this way, how many times should I need to access these anyway, famous last words.
Dave.
07-01-2016 #5
Have you thought about safety relay, estop, fuses etc
07-01-2016 #6
07-01-2016 #7
Advice on a charge controller please :)
By blackburn mark in forum General ElectronicsReplies: 23Last Post: 04-05-2020, 07:28 PM -
Help needed Dahlgren System 4824 And a DSC controller, what software will run it???
By fraserguitars in forum Machine DiscussionReplies: 0Last Post: 13-12-2015, 08:22 PM -
USB/Ethernet controller for Mach3/4 advice
By paulus.v in forum Control Hardware & SystemsReplies: 17Last Post: 17-02-2015, 09:37 PM -
Advice please! JAF Motion Controller issues!
By Mark Chard in forum Machine Control SoftwareReplies: 0Last Post: 31-01-2014, 05:03 PM -
Which controller and motors? Newbie advice please
By Nealieboyee in forum Motor Drivers & ControllersReplies: 14Last Post: 16-10-2012, 02:56 PM
