Thread: CNC Masters
10-01-2016 #3
That's a lot of money by the time you have imported what is essentially a £1300 machine. The conversion wouldn't cost £4200.
Also it's round column machine which isn't the best for CNC conversion because of the head ache with tramming etc every time you move the head or crash it hard.
In typical marketing style they try to make a poor feature sound good. They state direct motor drive and make out it's a good thing compared to having belts. This isn't the case and Motor connection with belts is much better because it reduces resonance affects on the motors and gives smoother running.
They also state Manual use and show handles on the rear of the steppers. This isn't ideal either because the inertia of the handles spinning all the time affects motor performance.
If you have Warco then why not convert it.? . . . That's all this machine is.!
