Page 6 of 8 FirstFirst ... 45678 LastLast
  1. #51
    Thank you may be of interest please pm me with a price, may help me to decide which way to go
  2. #52
    Steve - I would think about £50 for disk, +licence + spiral bound manual. Works very well. You would certainly not want to pay what I paid for it!!!
  3. #53
    No that was one of the reasons I was going other way, for not much more money I had a updated machine with up to date software I already have mach3, leave it with me and get back to you, may be a idea while I collect bits, unfortunately I don't have home until tomorrow to see if it even moves
  4. #54
    HI Chris
    Im modifying a simalar machine using all the same bits as you CHD556, a KK01 Bob, and a UC100 Motion control, PLEASE can you help with some pointers on some of your wiring of existing bits,
    1/ how did you rewire the 8 wire stepper motors?
    2/ what did you do with existing PSU how did you wire that?
    Thank you
  5. #55
    First let me say I know this is an old thread, but I just received the same CNC and was also wanting to do a mach3 conversion.. Gleaning from the previous post it looks like I can reuse the stepper motors and just need to replace the drivers and PSU, then a motion controller..
    I ordered everything I think I need to get it done..
    Shopping list:
    x3 STEPPERONLINE CNC Stepper Motor Driver 1.0-4.2A 20-50VDC 1/128 Micro-step Resolutions for Nema 17, 23, 24 and 34 Stepper Motor
    x1 LETOUR DC Power Supply 36V 350W AC 110V Voltage Converter DC 36V Adapter Aluminum Shell LED Power Supplies for Visual Doorbell, Brake Machine, Electric Driver (Silver) DC 36V 9.7A POWER SUPPLY
    x1 SainSmart 5 Axis Breakout Board for Stepper Motor Driver CNC Mill
    x1 C2G/Cables to Go 10338 DB25 Female Parallel Add-A-Port Adapter Cable with Bracket (11 Inch)
    I already have a ESS (Ethernet Smooth Stepper) to use from a previous build..
    Is there anything else you can think of?
    Also to Steve-m, if you haven't figured out how to wire the motors I think they should be wired like the attached photo (please confirm if I am wrong).. this is based on the pdf here
  6. #56
    Hi
    cant remember what parts i used for mine i will have a look in sunday when im back in workshop and let you know
    Steev
  7. #57
    Thanks a bunch!!
  8. #58
    So i started taking mine apart tonight, hoping it was going to be an easy wire up.. well this one is using different steppers.. Mine has these installed..
    Also for some odd reason the wiring color does not match what the diagrams show :(
  9. #59
    ok good news.. i think.. It looks like the 8 wires coming off of the stepper are already bundled together and only 4 wires are coming into the DB9 connection.. the other wires are the limit switches.. I think i might be able to finish wiring this thing up this weekend.. maybe..
    Attachment 24426
  10. #60
    Quote Originally Posted by mchipser View Post
    Attachment 24426
    Here is the wiring diagram I think it accurate based on the research.. hoping to start wiring it soon.. Don't judge the drawing :(
  1. Vevor 3020 cnc Autolevelling
    By iBeta in forum Machine Discussion
    Last Post: 22-11-2015, 07:08 PM
  2. DIY 3020 CNC I/O Board
    By Pointy in forum Electronic Project Building
    Last Post: 27-07-2015, 10:48 PM
  3. NCStudio to Mach3 question for a chinese 3020 router
    By Fivetide in forum Chinese Machines
    Last Post: 11-04-2015, 10:37 PM
  4. is a cnc 3020 right for the jobs i need doing
    By RsvRcarl in forum Milling Machines, Builds & Conversions
    Last Post: 28-03-2012, 01:34 AM
  5. Improving your CNC3040/3020
    By DanielF in forum Motor Drivers & Controllers
    Last Post: 22-11-2011, 01:48 PM
