Thread: Isel CPM 3020 - run with mach3?
17-01-2016 #20
Chris,
It depends totally on which drivers you choose. Obviously (hopefully) the PSU voltage cannot be higher than the max spec on the drivers. The higher the voltage the faster rise time the driver can achieve pushing current through the windings of the steppers. If the voltage is too low the driver will give a sluggish performance. Although steppers have a nominal voltage rating they are essentially current operated devices.
Vevor 3020 cnc Autolevelling
By iBeta in forum Machine DiscussionReplies: 8Last Post: 22-11-2015, 07:08 PM -
DIY 3020 CNC I/O Board
By Pointy in forum Electronic Project BuildingReplies: 10Last Post: 27-07-2015, 10:48 PM -
NCStudio to Mach3 question for a chinese 3020 router
By Fivetide in forum Chinese MachinesReplies: 3Last Post: 11-04-2015, 10:37 PM -
is a cnc 3020 right for the jobs i need doing
By RsvRcarl in forum Milling Machines, Builds & ConversionsReplies: 3Last Post: 28-03-2012, 01:34 AM -
Improving your CNC3040/3020
By DanielF in forum Motor Drivers & ControllersReplies: 0Last Post: 22-11-2011, 01:48 PM
