Thread: Aluminium profile cnc build
25-07-2016 #32
In which point you would need more details? Just let me know. I tried to give screenshots of every important point, but if there is something you would like to see i can put them in here.
How about the whole frame structure, z axis and things like that?
Išsiųsta naudojantis SM-G900F Tapatalk 4 Lt
Do I detect sarcasm ?
So in my case i have it 10mm and attaching it to the other plate with M6 screws. Is that allright?
Is your measurement just to the end of the key in the shaft?
http://cnc4you.co.uk/resources/Stepp...1B%203.1Nm.pdf..Clive
25-07-2016 #34
No. No sarcasm at all i cant understand why you spoted it in there. It is all good! :)
My "other" plate is the one on which is going motors mounting plate and both of them are making 90 degree angle. And whole this assemble is mounted onto the leg.
About the shafts in my model they are the round ones whitout key. So i will go for the key shaft for longer shaft and better grip for grub screws.
25-07-2016 #35
Valdis in Reply to your PM then can't see any major issues with the design. Couple of small suggestions but other than these nothing seriously wrong.
#1 I would brace the connection between bearing plate and gantry side.
#2 Would bring the rails on the Gantry to front slot to lessen the lever affect.
25-07-2016 #36
25-07-2016 #37
#1 If I move rails to the front slot i will have bigger gap between gantry and Z axis back plate (at the moment it is 3mm) if I am using wide carriages. Maybe i could use the narrow ones the same like on Z axis?
#2 How i could brace that connection? I have some of these so i could use them.
They are 40x40 and 6mm thickness.
OR this version?
25-07-2016 #38
25-07-2016 #39
03-08-2016 #40
Some small update from me :)
During last days as i been advised moved Y axis rails to the front slot, then made a bit smaller plate on which going Z axis motor so saved some unnecesary weight. Now trying to find out the cable routes..
For the cables and water pipes on the gantry I done a channel from 1mm sheet metal just to see how it looks. Not sure if it will be strong enough to hold the chain.. Any suggestions on that?
Started to look for the companies which does aluminuum extrusions, got some quotes. The best price for all the extrusions seen in my model was £340, which is bit more than i expected, but i guess thats the price for them. Does anyone knows a good supplier for them where i could get for the best price? Thanks guys.
Aluminium Profile - ValuFrame?
By Tenson in forum Marketplace DiscussionReplies: 12Last Post: 24-09-2020, 07:21 PM -
Aluminium Profile
By amxen in forum Metalwork DiscussionReplies: 2Last Post: 13-08-2015, 07:37 PM -
eBay: KB Aluminium Profile Supplies
By KB Aluminium in forum Items On eBay UKReplies: 45Last Post: 20-05-2015, 03:46 PM -
aluminium profile for cutting bed of router
By steeplejack in forum Marketplace DiscussionReplies: 3Last Post: 19-10-2013, 10:52 PM -
Tapping Aluminium profile
By jonbabbz in forum Tool & Tooling TechnologyReplies: 3Last Post: 28-05-2012, 08:09 AM
