Page 3 of 9 FirstFirst 12345 ... LastLast
  1. #21
    I opened the bracket the same like you showed me, but i still have 8mm left. I checked motors dimensions and pulleys dimensions all seems ok. Where that difference could come from? Maybe you are using different pulley?
  2. #22
    Lives in Marple Stockport, United Kingdom. Last Activity: 16 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,345. Received thanks 618 times, giving thanks to others 87 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by valdis034 View Post
    The shaft on a nema 23 from Cnc4you is about 22.5mm long.
  3. #23
    The one in my drawing is 20.6 mm and it is exactly the same like in any drawing you could find on internet with nema 23 dimdnsions. Double standard?
    Išsiųsta naudojantis SM-G900F Tapatalk 4 Lt
  4. #24
    Is your measurement just to the end of the key in the shaft?
    http://cnc4you.co.uk/resources/Stepp...1B%203.1Nm.pdf
  5. #25
    My motor shafts don't go all the way through the pulley and have been running fine for years.
    If it is more than half way into the pulley and the grub screws have a good lock onto the shaft I don't see any major problems.
  6. #26
    Just looked at my Z axis and it looks a little like this.....
    Shaft is 3/4 the way in the pulley and held on with 2 off M3 grub screws @ 90° to each other...
    Plate thickness is 3mm so 17mm pocket machined out the plate.
    Neil...
    Build log...here
  7. #27
    So do we actually need that thickness of a plate if anyway we are machining almost all the through the thickness?
  8. #28
    It has to have some inherent stiffness to stop any bending forces from the belt, I had it 20mm thick as it came out the same sheet as the rest and I needed the thickness to put the M8 bolts into....
    Neil...
    Build log...here
  9. #29
    So in my case i have it 10mm and attaching it to the other plate with M6 screws. Is that allright?
  10. #30
    Is there any chance that somehow i have blocked my posts, so others cant see it? The same with massages? Or people just doesnt respond as much as i would like? :D
  1. Aluminium Profile - ValuFrame?
    By Tenson in forum Marketplace Discussion
    Last Post: 24-09-2020, 07:21 PM
  2. Aluminium Profile
    By amxen in forum Metalwork Discussion
    Last Post: 13-08-2015, 07:37 PM
  3. eBay: KB Aluminium Profile Supplies
    By KB Aluminium in forum Items On eBay UK
    Last Post: 20-05-2015, 03:46 PM
  4. aluminium profile for cutting bed of router
  5. Tapping Aluminium profile
    By jonbabbz in forum Tool & Tooling Technology
    Last Post: 28-05-2012, 08:09 AM
