Thread: Aluminium profile cnc build
17-10-2016 #41
Hi. Here is what Fred wrot to me: Please attention the BK12 support we quota to you are in cheaper type with normal Deep groove ball bearing,if you prefer better quality BK12,we have P5 grade with Angular contact bearing type,seems many customers from UK are like this superior type,if change to P5 AC bearing type,the amount will be increase USD58.00 for the 4set.
Which one you would take? I seen somewhere talking about them cant find now.
Got quotes from aluminium warehouse for my aluminium plates, is it about right?
10mm plate
80 x 67 2pcs 6082 £4.10 ea tooling £5.46 ea
80 x 80 4pcs 6082 £6.58 ea tooling £8.75 ea
80 x 40 1pc 6082 £2.85 ea tooling £3.75 ea
114 x 120 1pc 6082 £10.76 ea tooling £14.32 ea
87 x 87 4pcs 6082 £6.58 ea tooling £8.75 ea
45 x 60 1pc 6082 £2.40 ea tooling £3.20 ea
50 x 60 1pc 6082 £2.00 ea tooling £4.20 ea
20mm plate
200 x 67 2pc 6082 £26.30 ea tooling £35.00 ea
200 x 50 1pc 6082 £16.40 ea tooling £21.81 ea
25mm plate
45 x 60 2pcs 6082 £6.00 ea tooling £7.98 ea
50 x 60 2pcs 6082 £6.58 ea tooling £8.75 ea
Cariage £22.30
17-10-2016 #42
Yes go with the P5 AC bearings they are far superior and worth the extra cost.
18-10-2016 #43
Hi valdis34, can I ask you a couple of questions on the material suppliers?
Where are you getting your aluminium slotted profile from?
It says 'tooling' on the quote for plates, are they machining them to your drawings ie holes faces etc ?
Many thanks
Tony....
18-10-2016 #44
Hi. There are quite a lot of companies here in UK which are doing extrusions. Did not buy them yet, but probably it will be company called Alprofil.
No, i will get all those pieces from the quote only cut to size, and will drill them myself. Aswell I will need some plates to be machined.
18-10-2016 #45
Those Aluminium prices seem high, but I guess I'm used to prices from my local supplier Taybroh Alloys in Eastington, Gloucestershire...might be worth giving them a ring to see if they will send to you?
18-10-2016 #46
Yeah anything thats helps to reduce the price.. Found local machinist guy, so he will give me a quote for them in a next few days. Want to finally actualy start building it!
Išsiųsta naudojantis SM-G900F Tapatalk 4 Lt
20-10-2016 #47
Did someone bought linear parts from aliexpres sellers the jason august store, huijuan mei or transmission cnc? They are quoting a bit cheper..
20-10-2016 #48
Hi Valdis
You must have got the same email as i did this morning, @ least the seller is quoting genuine Hiwin. A lot of the sellers will show Hiwin in there add but if you check the description it says picture is just for general information and the supplied item will prevail so chances are they won't be Hiwin.
Regards
Mike
31-10-2016 #49
Which spindle bracket is better? Thinking if they will have the same strenght?
This one:
http://www.ebay.co.uk/itm/Dia-80mm-S...3D322225414288
or this one
http://www.ebay.co.uk/itm/80mm-Diame...3D322225414288
31-10-2016 #50
Should be the same I think.
Aluminium Profile - ValuFrame?
By Tenson in forum Marketplace DiscussionReplies: 12Last Post: 24-09-2020, 07:21 PM -
Aluminium Profile
By amxen in forum Metalwork DiscussionReplies: 2Last Post: 13-08-2015, 07:37 PM -
eBay: KB Aluminium Profile Supplies
By KB Aluminium in forum Items On eBay UKReplies: 45Last Post: 20-05-2015, 03:46 PM -
aluminium profile for cutting bed of router
By steeplejack in forum Marketplace DiscussionReplies: 3Last Post: 19-10-2013, 10:52 PM -
Tapping Aluminium profile
By jonbabbz in forum Tool & Tooling TechnologyReplies: 3Last Post: 28-05-2012, 08:09 AM
