  1. #4
    Quote Originally Posted by valdis034 View Post
    Thanks for the answer. What could be better to drive those two ballscrews with seperate motors, or put one motor in the middle and drive both screws with a belt? and if we run each screw with separate motor so this means we need adittional driver, or it will be enough one driver which has enough power to handle the current of both motors?
    Išsiųsta naudojantis SM-G900F Tapatalk 4 Lt
    Well that debate has been going on for a long time and both ways have there pro's & con's. If using one motor it normally needs to be bigger and generally a higher voltage on the drive. But you only need one homing switch on one side.
    Using two motors you will need two drives and two homing switches to make sure the gantry is square and good drives with stall detect in case one motor stalls and tries to rack the gantry.
    It is not a good idea to use one drive with two motors.
    Both systems if correctly done work fine.
  1. Aluminium Profile - ValuFrame?
    By Tenson in forum Marketplace Discussion
    Last Post: 24-09-2020, 07:21 PM
  2. Aluminium Profile
    By amxen in forum Metalwork Discussion
    Last Post: 13-08-2015, 07:37 PM
  3. eBay: KB Aluminium Profile Supplies
    By KB Aluminium in forum Items On eBay UK
    Last Post: 20-05-2015, 03:46 PM
  4. aluminium profile for cutting bed of router
  5. Tapping Aluminium profile
    By jonbabbz in forum Tool & Tooling Technology
    Last Post: 28-05-2012, 08:09 AM
