[QUOTE=Washout;75806]Hi Rusty
Welcome aboard firstly.
Thanks a million for the info . I really enjoyed your videos. Whats the name of the machine you use or is it something you assembled yourself ? I was trying to budget at around 2-2500 euros as I had planned to buy the set of acoustic cnc plans from "Ultimate Guitar Plans Online" and load them. They are quite expensive but it would hopefully be a one off purchase. Its looking doubtful if I will find a machine that suits at that price though. But, I will keep trying anyway.
Thanks again
Rusty
15-01-2016 #2
[QUOTE=rusty999;75821]The machine is home designed/built (with plenty of helpful advice from the folks here)- there is a build log thread somewhere - I'll see if I can fish it out.
I probably have more rigidity and therefore more cost in my machine than you would need if you stick strictly to woods/plastics and mine came in around £2,500 including software (I've spent a bit more since I built it in some upgrades). So you would likely squeeze in at your intended budget and especially if you can weld a steel frame rather than using extrusion - that's trading ease of assembly for cost/time.
I would advise extreme caution when looking at commercial machines - there are lots of snake-oil merchants out there selling under specced machines for overspecced prices IMHO and you only need to look at milling machine prices for non-CNC and CNC variants of the same machine to see this i.e. £3000+ price difference for a few steppers, ballscrews and brackets etc. in some cases.Last edited by Washout; 15-01-2016 at 10:35 AM.
My CNC Projects: https://www.youtube.com/imadethisoncnc
15-01-2016 #3
Hi Welcome,
Ok well unless you build your self then you'll struggle to find a machine that size with only £1900 (2500euro) that is any good. Washout's warning about Commercial machines is very very sound advice. Here's why.!!
I build machines for people and I can tell you it's not possible to build good machine with decent quality components at this size and make enough money to make it commercialy viable. So if they are selling machines at this size for £1900 or less then something is wrong or compromised.
I'm often contacted by people who have been bitten by the Snake oil Merchants when there machines don't work as expected or more often the case breaking down every other week or day. Mostly this happens because they cut corners in areas that matter most, ie: Electronics or Linear rail/Screws. Now to be fair I don't class these sellers so much Rip off Merchants more preditors looking for Green CNC buyers who know no better.
But this happens with machines costing £10K and people who have done some research still get bitten and it's these people who are Rip off merchants.
So be careful because you are the kind pray the preditors are looking for. By that I mean someone with no or much desire to self build and with more than couple of hundred pounds to spend.
If you see anything then run it by the Forum and well give you an honest opinion on it.
Guitar Hero Meets, T-Slotted Profiles !!!
By Lee Roberts in forum General DiscussionReplies: 4Last Post: 24-04-2019, 12:20 AM -
New project - Aluminium Guitar Nut Height Gauge
By Washout in forum Metalwork Project ShowcaseReplies: 11Last Post: 08-10-2015, 10:04 AM -
newbie to the forum looking for info
By CClearout in forum Marketplace DiscussionReplies: 6Last Post: 08-09-2012, 09:44 AM -
NEW MEMBER: Hi all - Seeking advice for a new project
By julian in forum New Member IntroductionsReplies: 3Last Post: 23-06-2012, 02:53 PM -
NEW MEMBER: New member seeking advice
By Rob Wol in forum New Member IntroductionsReplies: 14Last Post: 02-02-2012, 10:54 PM
