11-02-2016 #22
Cause it seems a bit expensive to buy the kit for blackening at the moment. The torch is easy,cheap and toughens the material. No quenching, air cooling. But that would be the next logical step
Now about Power.
Motor power. I was lead to believe / from forums/ that you need at least 1hp per inch belt, so i decided the machine to have 1.5kw motor. Mean while i had
made my self a 12" sander. 3 phase 0.75kw motor that run on 230VAC using capacitor, no VFD. The disc was easy to stop. See video below. So i decided to invest in a VFd cause i wanted to run it from 0-3000RPM depends what i am doing. I connected it yesterday. Man, i could not stop it in any way, its brutally strong combo. And only 0.75kw.
So i am starting to believe there is some misconception here. Cause belt is not wider than portion of disc i used for grinding yesterday.And as i said, i couldnt stop it pushing hard using steel bar. So i started to think thats the pulley mass is to blame. while all pulleys i designed are very much big bored and so they are light, the motor wheel is a whopping 1.6kg at 120mm. I started redrawing it recessed in the middle but could not lower the mass less than 1.1kg. So i went further and made all walls 8mm only. Weight dropped to 680g.
So in short i start to think that this could be driven using 0.75kw motor combined with VFD instead of the over sized 1.5kw, when pulleys weight is made minimum. yet to prove on next machine. of course i will see how much i need that low revs where is a small loss of power
Below video of the 0.75kw motor when runs on capacitor on 2 phase line
And video of same motor that runs on VFD again 2 phase line. I could not stop it pushing very hard against it a 40x10mm steel bar.Trying seriously to abuse it . The disc itself is a very thick diamond cut disc and the blue sanding disc thats glued, is a 60 grit zirconia. So you judge what a beast it is now with the VFD connected.
Its very interesting to me if sb has a similar machine, 12" disc sander using 1400RPM mono phase motor, no VFD and if it could be stopped pushing hard against it?????
PS. Black lines on disc are from sharpening my pencils. Disc is new otherwise. First i run it at half speed and then at full speed at 100hz. It was scary to hold thebar with only one hand.
"Hacking" and "Modding"
Centerless grinder LOESER RPS 374 - in Europe
By Grinder in forum Opportunities Available & SoughtReplies: 1Last Post: 24-11-2014, 04:53 PM -
"Racks" VS "ball screw"
By C.AlveSilva in forum Linear & Rotary MotionReplies: 1Last Post: 17-04-2012, 11:53 PM
