thank you guys for the insight and preventing me from making a mistake, I guess the VFD manual confused me because it has some notes about when using a contactor. so in this case is there use for a contactor (for the VFD) at all if controlled through a constant turn on signal?
21-01-2016 #2
appreciate your input on following related subject as well: at the moment the planned way to start/stop the spindle is through input signal coming from CSMIO (the usual way) , in case of problems and I hit E-Stop, naturally CSMIO will disconnect that signal and spindle will stop normally.
is that sufficient or should I utilise the other input ports of my VFD, it has a total of 8 ports to accept commands from a controller.
they are as following:
0 - No Effect
1 - first multi speed ( references a table in the manual )
2 - second multi speed ( references a table in the manual )
3 - third multi speed ( references a table in the manual )
4 - frequency rises
5 - frequency decreases
6 - forward jog
7 - reverse jog
8 - forward ( this is what I used before and works fine and is enough to start/stop it )
9 - reversal
10 - forward trigger
11 - reverse trigger
12 - stop
13 - freely shutdown
14 - forced shutdown
15 - forced inversal
16 - counter is cleared
17 - counter input
18 - program run reset
19 - external fault
20 - external reset
21 - accelerate and decelerate - time choosing first ( references a table in the manual )
22 - accelerate and decelerate - time choosing second ( references a table in the manual )
23 - accelerate and decelerate pause
24 - force ACI passage effective
I don't understand most of them but its a direct copy-paste from the manual.
so is it worth doing a setup where one of those functions is triggered during E-Stop? maybe the stop or external fault? hehe feels like overthinking things
Electric motorbike racing
By Jonathan in forum General DiscussionReplies: 46Last Post: 16-08-2016, 03:28 PM -
PSU Assistance
By CNCStudent in forum General ElectronicsReplies: 13Last Post: 05-08-2015, 07:07 PM -
FOR SALE: 240v decent electric filter
By DrNik in forum Items For SaleReplies: 3Last Post: 16-03-2015, 12:30 PM -
ES-D1008 + CSMIO/IP-S wiring
By Matt81 in forum CS-Lab (CSMIO)Replies: 3Last Post: 03-05-2014, 10:56 PM -
NEW MEMBER: Tunisien request for assistance
By ali hedi in forum New Member IntroductionsReplies: 0Last Post: 01-06-2009, 05:37 PM
