Thread: Cnc plasma build need help plz
You have several problems regards speed.?
24V isn't enough voltage you really need around 40-45Vdc to get any decent speed from those motors. I'll Also take a guess that they are high inductance motors which makes things worse with low voltage.
Then you have 5mm pitch screws which will limit your rapid speed.
But to get a better idea of your setup we need more info.
Are you using parallel port.?
Are you using direct drive to screws or do have belts with reduction.?
What micro stepping on the drives.?
What values do you have in Motor tuning. :ie Steps Per, Velocity, Acceleration for each axis.?
When you say slow how slow exactly what's the Max rapid you can achieve.?
17-01-2016 #2
Hi
im using a parallel port
its that slow it is barely noticeable
leadshine drivers have a software called pro tuner
plug a cable from driver to serial port and I can get decent speeds
but in Mach 3 it's super super slow
ive tried all sorts of step per in motor tuning etc
also tried lots of different micro step setting
limits and estops work as they should
motors are direct drive
because they work with the pro tuner software which connects to the serial port Tells me it's either parallel port related or breakout board
thanks
for the reply
17-01-2016 #3
That tells me nothing and Steps per isn't something you guess at it's a fixed number dependant on screw Pitch and Micro stepping.
One thing that could be doing this is if you have the Units set to Inch but using Millimeter to calculate Steps per.
No if you can Jog around then everything is working as it should. The only thing that could limit speed is if you have the JOG speed set low.
17-01-2016 #4
Sorry i meant I've tried different steps per just out of curiosity.
jog speed is set to 100%, units are set in mm
Sorry I this sounds dumb I'm still learning and thank you for replying :)
17-01-2016 #5
No don't worry you don't sound Dumb but just saying I've tried all sorts doesn't help anyone help you so that's why said doesn't tell me anything.
Give the Info I asked for and we'll see about getting you going.Last edited by JAZZCNC; 17-01-2016 at 09:58 PM.
17-01-2016 #6
post a screenshot of your mach3 motor tuning page? also advise what the microstepping resolution it. if you are direct drive to the ballscrews and they are 5mm pitch, then it is quite simple to set up.
17-01-2016 #7
Ok I will get back to you tomorrow as I'm not in my workshop at the moment
Thank you
My plasma build 8 x 4
By drumsticksplinter in forum DIY Plasma Build LogsReplies: 7Last Post: 01-02-2014, 10:39 PM -
my plasma build mk2
By oadamo in forum DIY Plasma Build LogsReplies: 8Last Post: 08-06-2011, 10:25 PM -
my first plasma build
By oadamo in forum DIY Plasma Build LogsReplies: 11Last Post: 31-12-2010, 07:15 PM -
My first Plasma build
By D-man in forum Plasma Table MachinesReplies: 4Last Post: 10-07-2010, 02:27 AM -
3M x 2M Plasma table build
By MonoNeuron in forum DIY Plasma Build LogsReplies: 14Last Post: 01-09-2009, 11:11 AM
