    Quote Originally Posted by Lewywri89 View Post
    Sorry do you mean what microstep the drive is set at
    If so it iz 800
    Sent from my D6503 using Tapatalk
    Yes so try these new numbers and see what happens. Think you'll find a bit of difference.!! You'll go from Max velocity of 750mm/min to potential velocity of 9350mm/min thou you'll never get that with 24v and 5mm pitch screws.
    25000khz / 2000 = 12.5mm per Sec * 60 =750mm/min
    25000khz / 160 = 156.25 per sec * 60 = 9375mm/min
    So has you see the Micro steps make big difference. So high Micro steps with low Pitch means more pulses to do same speed and you only have so many pulses. In this case 25000 per sec.
    800/5=160 steps per
    Also just to make clear the Steps Per setting isn't a number you can play with to suit the speed. It's a Fixed number based on the number of steps required to move one unit, in this case 1mm. This number is got from the calculation of Micro steps divided by screw pitch.
    800/5=160 steps per
    Okay thank you will post back my results 2moz
    Lewis
    Lewis
    Lewis I have just read your entire post. Do yourself a favour and get another power supply as you are running on 24V and those drives Max is 50V so about 40 - 45V would be fine. It will make a huge difference to your machine
  1. My plasma build 8 x 4
    By drumsticksplinter in forum DIY Plasma Build Logs
    Last Post: 01-02-2014, 10:39 PM
  2. my plasma build mk2
    By oadamo in forum DIY Plasma Build Logs
    Last Post: 08-06-2011, 10:25 PM
  3. my first plasma build
    Last Post: 31-12-2010, 07:15 PM
  4. My first Plasma build
    By D-man in forum Plasma Table Machines
    Last Post: 10-07-2010, 02:27 AM
  5. 3M x 2M Plasma table build
    By MonoNeuron in forum DIY Plasma Build Logs
    Last Post: 01-09-2009, 11:11 AM
