    Yes so try these new numbers and see what happens. Think you'll find a bit of difference.!! You'll go from Max velocity of 750mm/min to potential velocity of 9350mm/min thou you'll never get that with 24v and 5mm pitch screws.
    800/5=160 steps per
    Okay thank you will post back my results 2moz
    Lewis
    Sent from my D6503 using Tapatalk
    Lives in Marple Stockport, United Kingdom. Last Activity: 20 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,346. Received thanks 619 times, giving thanks to others 89 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by Lewywri89 View Post
    Lewis
    Lewis I have just read your entire post. Do yourself a favour and get another power supply as you are running on 24V and those drives Max is 50V so about 40 - 45V would be fine. It will make a huge difference to your machine
  1. My plasma build 8 x 4
    By drumsticksplinter in forum DIY Plasma Build Logs
    Last Post: 01-02-2014, 10:39 PM
  2. my plasma build mk2
    By oadamo in forum DIY Plasma Build Logs
    Last Post: 08-06-2011, 10:25 PM
  3. my first plasma build
    Last Post: 31-12-2010, 07:15 PM
  4. My first Plasma build
    By D-man in forum Plasma Table Machines
    Last Post: 10-07-2010, 02:27 AM
  5. 3M x 2M Plasma table build
    By MonoNeuron in forum DIY Plasma Build Logs
    Last Post: 01-09-2009, 11:11 AM
