Thread: Single Point Thread Mills
	18-01-2016 #1
Does anyone know of a UK supplier of single point thread mills? I can't find anything via Google - Am I even calling these things by the right name?
Matt.
	18-01-2016 #2
Hi Matt,
Try,
http://www.cutwel.co.uk/thread-makin...c-thread-mills
Regards
Sean
	18-01-2016 #3
Hi, thread Mills generally have multiple thread forms along the the length as you can see in the cutwel link.
In the past I have used a indexable lathe screw cutting tool as a milling cutter, and this would effectively be a single point tool.
	18-01-2016 #4
Generally... and then there are these:
http://www.drill-service.co.uk/Produ...20000&Tool=799https://emvioeng.com
The Following User Says Thank You to komatias For This Useful Post:
	18-01-2016 #5
And these from Germany http://www.sorotec.de/shop/Cutting-T...illing-cutter/ delivery is fairly quick
	18-01-2016 #6
Are those Carbide?
	18-01-2016 #7
I think so, but I will check with Sorotec.
	18-01-2016 #8
Yes the Sorotec thread mills are carbide.
The Following User Says Thank You to cropwell For This Useful Post:
	18-01-2016 #9
Datron https://www.datron.de/de_de/cnc-frae...er.html#_c4992 and paul horn https://www.phorn.de/produkte/fraesen/ both in Germany making thread mills as well. The horn parts are for larger diametres. If you have thread tools for a lathe, then you can use these parts on the mill as well, if you can clamp it in a collet.
	18-01-2016 #10
I have a range of metric and imperial thread mills for specific jobs but for oddball OD and for internal stuff down to about 11mm I use one of these -
http://www.iscar.com/eCatalog/Item.a...FSTYP=M&srch=1
With a threading tip, there are a range of tips for other purposes -
http://www.iscar.com/eCatalog/Family...geType=4&rel=I
If you can get a good deal on a thread mill that has a few teeth on a decent length shank you can grind it down to one fairly easily and cut a range of threads with it, keep in mind that if you move too far from the intended diameter for ID cutters the thread form can come out slightly off,
- NickLast edited by magicniner; 18-01-2016 at 08:07 PM.
Setting the zero point on a CNC lathe
By Robin2 in forum Lathes, Lathe Rebuilding & ConversionsReplies: 7Last Post: 20-10-2013, 10:37 PM -
By Robin2 in forum Machine DiscussionReplies: 7Last Post: 20-10-2013, 10:37 PM -
Setting a start point.
By jrob3rts in forum Computer SoftwareReplies: 14Last Post: 17-06-2012, 12:36 PM -
FOR SALE: Mills, Thread Mill, Carbide Drills...
By Jimmybristol in forum Items For SaleReplies: 1Last Post: 21-03-2011, 01:47 PM -
FOR SALE: End mills and Ball mills for sale......
By Jimmybristol in forum Items For SaleReplies: 2Last Post: 16-02-2011, 12:37 AM
