    Are those Carbide?
    https://emvioeng.com
    I think so, but I will check with Sorotec.
    Yes the Sorotec thread mills are carbide.
  4. The Following User Says Thank You to cropwell For This Useful Post:
  5. #4
    Datron https://www.datron.de/de_de/cnc-frae...er.html#_c4992 and paul horn https://www.phorn.de/produkte/fraesen/ both in Germany making thread mills as well. The horn parts are for larger diametres. If you have thread tools for a lathe, then you can use these parts on the mill as well, if you can clamp it in a collet.
  6. #5
    I have a range of metric and imperial thread mills for specific jobs but for oddball OD and for internal stuff down to about 11mm I use one of these -
    http://www.iscar.com/eCatalog/Item.a...FSTYP=M&srch=1
    With a threading tip, there are a range of tips for other purposes -
    http://www.iscar.com/eCatalog/Family...geType=4&rel=I
    If you can get a good deal on a thread mill that has a few teeth on a decent length shank you can grind it down to one fairly easily and cut a range of threads with it, keep in mind that if you move too far from the intended diameter for ID cutters the thread form can come out slightly off,
    - Nick
  1. Setting the zero point on a CNC lathe
    By Robin2 in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 20-10-2013, 10:37 PM
  2. Setting the zero point on a CNC lathe
    By Robin2 in forum Machine Discussion
  3. Setting a start point.
    By jrob3rts in forum Computer Software
    Last Post: 17-06-2012, 12:36 PM
  4. FOR SALE: Mills, Thread Mill, Carbide Drills...
    Last Post: 21-03-2011, 01:47 PM
  5. FOR SALE: End mills and Ball mills for sale......
    Last Post: 16-02-2011, 12:37 AM
