18-01-2016 #3
Hello Andrew
Many thanksfor such a detailed reply.
I will tryand tell you what if think we need here.
We have a100amp overhead supply into the house PME supply. The work shop in question isvery small only 20ft x 8ft on the consumer unit we have a 50amp MCB for thesmall workshop going into that we have a 3 core 10mm2 SWA cable going 70meters, at the workshop end is a 6-way consumer unit. I only need a couple ofsockets. I have a twin socket (socket 1 on a 20amp MCB) that I was thinking ofkeeping for the CNC, plugging the 4-way surge protection lead into it and then puttingthe monitor, PC and the control box into the extension lead. I only have onstrip light with a plug on the end that I was going to plug into the secondtwin socket on its own MCB. There is no ground spike at the house or workshopwe understood the PME supply to be sufficient I am not sure only going on whatthe electrician told me. The workshop is a metal container and I have an earthspike on the shelf doing nothing, if need be I could bang it in the ground. Ifso would I put the cable into the consumer unit or just fix it to the shippingcontainer itself? Perhaps I am heading in the right direction or doing a no no!
Many thanks
Steve
Help re electrical input
By Jomach21 in forum Motor Drivers & ControllersReplies: 1Last Post: 08-06-2015, 12:30 PM -
Everything in one box (electrical)
By Blackrat in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 03-12-2014, 11:11 PM -
Noise, Interference, and unexplained electrical behaviour
By g4ghp in forum General ElectronicsReplies: 4Last Post: 24-04-2014, 11:39 AM -
Excellent info here regarding electrical noise, ideal for panels and machine wiring.
By EddyCurrent in forum General ElectronicsReplies: 0Last Post: 19-10-2013, 12:45 PM -
WANTED: Electrical Box for inverter
By badgerman in forum Items WantedReplies: 1Last Post: 28-09-2013, 11:08 PM
