Thread: Mini Lathe alignment
Hi Ed,
Sorry for the delay. This is the method I used. Probably frowned upon by proper machinists, but this is just a hobby, and it seems to work.
http://www.gadgetbuilder.com/Lathe_Align.html
First up just measure what you've got (mine wasn't great, vertically I had 0.13mm error over 190mm distance). Actually changing the alignment of the spindle can be done with shims (foil, drinks cans, etc) under various corners of the headstock casting. Getting access to the appropriate screws means you have to remove (or loosen at least loosen) the electronics box, motor, changegears, and leadscrew.
It's a bit of a faff, but taught me lots (like the fact the torque on the screws can affect the readings). End result is that vertical alignment is now ~0.01mm over 190mm, and horizontal alignment is better than I can measure.
Mini Lathe Part
By fragger6662000 in forum Milling Machines, Builds & ConversionsReplies: 2Last Post: 15-11-2011, 07:13 PM -
FOR SALE: Sieg C3 Mini Lathe
By Jonathan in forum Items For SaleReplies: 1Last Post: 07-05-2011, 06:19 PM -
Mini CNC lathe builders
By GeorgeD in forum Lathes, Lathe Rebuilding & ConversionsReplies: 7Last Post: 28-07-2010, 10:00 AM -
A Mini Lathe
By irving2008 in forum Milling Machines, Builds & ConversionsReplies: 19Last Post: 03-05-2010, 04:11 PM -
WANTED: SIEG C3 Mini Lathe
By derekm in forum Items WantedReplies: 5Last Post: 07-04-2010, 08:35 PM
