Thread: Water-cooled spindle tubing
Cheers Rob,
Just got word back on these:
10pcs/lot 6mm Tube M8 Thread Pneumatic Fitting Quick Joint Connector PC6-M8
http://s.aliexpress.com/IbA3QVjq
Says they are M8x1, if you go via the mobile app you get 16% off, works out about £5 for 10 or around 40p each, not quite the same as the others.
Dean how comes you change them for push fit type anyway, are the standard clamp type not very good that come with them?
.MeLee
22-04-2016 #2
Lee,
See post #5. My reason for wanting to change the fittings was that I couldn't get the original fittings to clamp down over the pipe (8mm OD 6mm ID). As I have many metres of this pipe, I didn't want to buy any more of a different size. I would have liked M8 male to 8mm push in, but couldn't find it directly. I have the brass, taps and dies to make an adapter, but couldn't be arsed to, when they were available to buy.
Rob
22-04-2016 #3
22-04-2016 #4
The Following User Says Thank You to Boyan Silyavski For This Useful Post:
23-04-2016 #5
23-04-2016 #6
Water cooled / air cooled 2.2kw spindle
By suesi34e in forum Generic Chinese SpindlesReplies: 15Last Post: 25-02-2015, 04:57 PM -
Do you need to water cool erhm a water cooled spindle?!!
By HankMcSpank in forum Generic Chinese SpindlesReplies: 18Last Post: 02-10-2013, 09:59 PM -
Cooling a water cooled spindle, without pipes everywhere & huge water tanks/buckets!
By HankMcSpank in forum Generic Chinese SpindlesReplies: 17Last Post: 18-09-2013, 06:32 AM -
Chinese 2.2 water cooled spindle / Which VFD ?
By dudz in forum Motor Drivers & ControllersReplies: 20Last Post: 16-08-2013, 02:22 PM -
By alex wight in forum Generic Chinese SpindlesReplies: 1Last Post: 21-09-2012, 09:57 PM
