25-01-2016 #31
Interesting; can you elaborate (or link to somewhere that explains) the advantages in laymans terms? I don't think I've ever seen it done that way... any construction challenges (alignment?)...? I guess it's only the same but inverted....
As an aside, I reworked the motor mount to be underslung for a pulley arrangement... using a generic eBay-sourced motor mount bracket
25-01-2016 #32
You want a design which keeps the alignment/support as close as possible to the cutting area, not one where the alignment/support moves away from the work area at either end of travel.
You can make the rails twice as long as the required travel and use multiple linear bearings to ensure support close to the cutting area.
Regards,
Nick
The Following User Says Thank You to magicniner For This Useful Post:
28-01-2016 #33
Right, I've made a decision! The design of a DIY machine can be parked because I'm going with this :-
http://www.mycncuk.com/threads/9412-Sieg-X3-and-Stand
...and I'll convert it over time. A home build came out at £1600 or so but my confidence that I'd build anything straight and true is low, probably more luck than anything. This X3 will let me do my aluminium parts without worry. Not sure how it'll be with accuracy on the PCBs but, pfft, we'll see. Nothing ventured, nothing gained - worst case I'll get an MF70 just for PCBs and convert that, using the X3 to make all the bracketry :)
If I had the space I've be doing a Bridgeport conversion but I don't have the space. If I was just doing large-area MDF and wood then likewise I'd be going with a home-made gantry system, but this approach just feels 'right' to me...
When I get round to starting it I'll post on here, might be a month or two yet, but I'll be honest at least :)
Thankyou all for your input; it has helped me make an informed decision and I've learnt a lot in the process, so that's been very useful and has helped me understand what I would be taking on.
"Hacking" and "Modding"
CNC machine "Spanish" model . Advice and opinions needed!
By shapebusters in forum Machine DiscussionReplies: 17Last Post: 12-03-2014, 06:21 AM -
Interesting Article "Makers unite - the revolution will be home-made"
By Fivetide in forum General DiscussionReplies: 4Last Post: 28-09-2012, 12:06 PM -
"Racks" VS "ball screw"
By C.AlveSilva in forum Linear & Rotary MotionReplies: 1Last Post: 17-04-2012, 11:53 PM -
My apologies to "Andy" for the delay ... internet connection problem
By ali hedi in forum General DiscussionReplies: 1Last Post: 25-12-2010, 06:05 PM
