    Hello everyone, as my first post was not visible (I don't know why) here goes a second try. I am building a table with a work area of 12x6. It will mainly do plasma cutting but the occasional routing job may come up so I am building the gantry stiffness with that in mind. I plan to go with all aluminum to reduce the size of the motors and have a table that is lighter and faster than if I were to go with steel. not to mention aluminum tubing comes with better dimensions on the faces than with cold roled steel tubing. So I have my drawings done I am putting the final touches on the lengths and dims of that and I wanted some feedback. Here I am posting this up for you guys to either chew me out some or give me some kudos for a job well done. Here goes nothing... please refer to pics and provide any info on the matter, Thanks
Name:	Table preliminary.png
ID:	17289   Click image for larger version.
Name:	Gantry Preliminary.png
  1. Fiirst Revision of my table 12x6 drawn, can i do my slats on test run
    Last Post: 21-01-2016, 08:06 AM
  2. Advice on Mammoth CNC Router Build - Steel Framed - 2440mm x 1220mm cutting area!
    By Wejjmeister in forum Gantry/Router Machines & Building
    Last Post: 03-01-2016, 12:45 AM
  3. BUILD LOG: My 1st Hybrid Steel/Ally (1150 x 850 work area) (comments/advice please)
  4. BUILD LOG: Melbourne Andy CNC build 1220x810 work area
