Page 1 of 5 123 ... LastLast
    OK so iv been trying to set up my 6040 cnc and to be honest i can run it and i have cut some MDF with it, but im not 100% happy with it. The problem i have is if i set the motor tuning to the recommended setting the steppers jam. To prevent this i have to run them at less than half the recommended settings. Here is a video of whats happening maybe someone can help,
    https://www.youtube.com/watch?v=O3I8...ature=youtu.be
    hope some one can help
    Lives in Marple Stockport, United Kingdom. Last Activity: 11 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,345. Received thanks 618 times, giving thanks to others 87 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    It would help if you gave some details about power supply, voltage, motor specs if you have them and driver.
    That would be a start so people can make an informed opinion. ..Clive
    Also do you have Mach3 set to mm or inches ?
    yer sorry this is what i have
    http://www.ebay.co.uk/itm/CNC-ROUTER...item2c5eac77af
    and this is what in the box and the steppers
ID:	13327Click image for larger version.
ID:	13328Click image for larger version.
ID:	13329Click image for larger version.
    i dont know if that helps.. i also have mach3 set to mm .
    thanks for the help Mick
    It looks like you have this setup;
    3163B Stepper Driver
    set to;
    Dynamic Current = 2.5A
    1/8 Microstep
    50% Standstill Current
    57HD5401-14S/8 Stepper Motor
    1.8 step angle
    6.6V
    3A
    2.2 Ohms
    8mH
    17kg/cm
    4 wire
    24v 8.3A DC PSU
    1605 ball screws
    And that being so, the settings you have seem to be okay as far as I can make out.
    However I did a conversion of the motor torque setting and 17 kg/cm = 1.6671305 Nm, this is not so good but as your video shows they are not under load.
    I think you could reduce the microstepping and see if that helps, remember to change the Mach3 'steps per' to match.
    5m pitch
    1.8 deg motor
    1/8 microstep (8)
    360/1.8 = 200
    200/5 = 40
    8 * 40 = 320 steps per
    Reduce microstepping to 2 by setting K1 ON, K2 OFF
    5m pitch
    1.8 deg motor
    1/2 microstep (2)
    360/1.8 = 200
    200/5 = 40
    2 * 40 = 80 steps per
  6. The Following User Says Thank You to EddyCurrent For This Useful Post:
  7. #6
    ok thanks ill try that. im rite in thinking at the moment they are both set to on. so all i need to do is switch k2 down on all three . Then change the steps per to 80 . I do have 3 of these i could try and see if its any better if that dose not work .
    http://www.ebay.co.uk/itm/EU-Free-Sc...item338efc0758
  8. #7
    Ok I'm lost now. Are you saying the board I'm using won't take 36v or the drivers that came with the kit won't take 36v
  9. #8
    Quote Originally Posted by amxen View Post
    Ok for the sake of clarity I take it you have two setups one purchased with the cnc and the other which is a set of drives and motors and a power supply is this correct. .Clive
  10. #9
  11. #10
    Yes that's correct
    I was going to make my own so I got all the parts together to make one. Then I found I don't have the time to prototype parts. So I thought I would buy one. . The photos and video are of the one I got form eBay. The link to the aliexpress is a kit of electrical parts I have that for the one I was going to ( May still do) make. But I can use the parts on the other if I need to. Not sure about the sub Bob now thow as I have a dedicated pc with a PP. Hope that's abit more clear. Thanks mick
  1. New 6040 owner looking for advice from others with a chinese 6040/3040
    By itsmillertime in forum Machine Discussion
    Last Post: 14-10-2019, 08:30 AM
  2. Chineese 6040 problems
    By Kendrick57 in forum Gantry/Router Machines & Building
    Last Post: 18-10-2015, 10:52 PM
  3. Chinese 6040 from uk eBay seller x axis problem
    By CommanderKenyon in forum Gantry/Router Machines & Building
    Last Post: 20-02-2015, 02:13 AM
  4. my 6040 experience (yeah, and problems) so far
    By jimbo_cnc in forum Machine Discussion
    Last Post: 07-10-2014, 11:26 AM
  5. Chinese 6040 CNC Router Advise Needed
    By Bob Hepple in forum Chinese Machines
    Last Post: 27-11-2013, 12:00 PM
