    toby's Avatar
    Lives in Essex, United Kingdom. Last Activity: 10-08-2020 Has been a member for 9-10 years. Has a total post count of 23.
    Hi Jazz thanks for the fast reply. I will be definitely taking your advice. The screenshots are settings the machine were videoed at.
    What is the difference in sound between running the roadrunner and jog button noise? Does the job button move with different settings?
    Thanks again for the speed and advice of your reply I'm all ears.
    The stepper motors are set inside the cabinet
    Z axis 3.5a, 10000
    Y axis 3.5a, 3200
    X axis 3.5a, 3200
    Ok well first I need to know if Mach3 is set to Metric or imperial Units.?
    Also you have the Micro stepping set way too high. Turn all down to 1600 for starters.
    Do you know how far one revolution of the Motor moves each Axis.? I will need to know this to help setup the Steps Per setting correctly.
    The difference between Jogging and running road runner code is the motor is running at higher RPM where Mid band resonance isn't an issue.
    toby's Avatar
    Hi Jazz
    The mach3 is set to metric. I don't know the revolutions and unfortunately I've got commitments till monday. So I won't get back to the machine til next week. I really appreciate the help, once I work out the revolutions I will get back to you.
    Hope you have a good weekend.
    Quote Originally Posted by toby View Post
    Ok well in this case your massively setup wrong and will be most of your prolem. Also given the nature of how each axis uses gears etc then there's a better way to find the Steps per setting.
    Here's what to do.!
    First Jog each axis into clear space with room to move.
    Set the drives micro steps to 1600. Then in Motor tuning set the Steps per number to 60, this is just tempory and I'm guessing the pitch will be 10mm. Set velocity and Accel to 1000 & 300. In motor tuning Remember to Click on each Axis to change then save after making changes.
    Then check to see if machine moves ok. If stalls then lower velocity.
    Now goto Settings Tab and just above Reset you'll see button called "Set steps per unit" . click on it and select the axis you want to set first. Enter a movement amount, make it small at first say 10mm. Then before pushing Enter mark the axis so can measure how far it moves.
    When you push enter it will and box will appeat asking how far it moved. Enter distance it traveled and it will work out the steps per setting for you and enter it into Motor tuning.
    Do this for each axis but remember the Z axis will need Negative number to move down.
    This will get you very close to correct and machine should move ok now. Now repeat but measure over a longer distance and try to measure accurate possible.
    Now your set to tune the velocity and acceleration to higher numbers but don't go to high else you'll get stalling motors.
    Also other reason why you struggled with Road runner was because the G-code is set for Inches not metric so the moves are tiny and because your machine is so badly setup it was double edge sword.
  6. #5
    toby's Avatar
    Jazz you deliver. Looking forward to get through this weekend and back to the machine on Monday now. Will report back with updates next week.
  7. #6
    toby's Avatar
    I've had a hectic few months with work but I've finally got a break in my schedule to dedicate the next 2 weeks to getting this machine up and running. I managed to take out the previous configuration of the x axis stepper motor and now instead of the the x axis stepper motor being on top of the gantry its fixed securely inside now with the full four bolts. On doing so I noticed one of the cogs had damaged teeth and had to get a new one made.
    Last night I had a couple hours free so I thought foolishly that I could get the VFD setup with mach 3 in this time. Anyway I followed the manual here http://www.omc-stepperonline.com/dow...ers_Manual.pdf but I wasnt entirely sure with the setup coming out of the VFD ASKPOWER A131 as all I could find were these instructions http://www.instructables.com/id/6-Ax...reak/?ALLSTEPS
    The spindles runs from the panel fine. All and any help is appreciated thank you in advance
  8. #7
    Ok this is easy to make happen but will require you changing some parameters in the VFD so you'll need the manual.
    If you can find the VFD manual I can describe how to do it. What you want to know is the Parmeter number for External frequency control for the Speed control. Also parameter for ON/OFF so can set to External control.
    On the Huanyang VFD's which this looks like but Isn't then it's parameter 01 & 02
  1. FOR SALE: Gerber system 48 cnc router for sale
    By Ahmed in forum Items For Sale
    Last Post: 22-04-2015, 12:11 AM
  2. gerber system 48 plus sizing problem
    By nodgeruk in forum Machine Discussion
    Last Post: 17-09-2014, 05:53 PM
  3. Gerber system 48
    By martin54 in forum Milling Machines, Builds & Conversions
    Last Post: 13-09-2013, 12:35 PM
  4. BUILD LOG: Gerber system 48 conversion
    By martin54 in forum DIY Router Build Logs
    Last Post: 25-08-2013, 11:29 AM
  5. Gerber system 48 Plus router
    By poppa jock in forum Machine Discussion
    Last Post: 29-07-2013, 05:43 PM
