22-01-2016 #1
Hi everyone, I recently redesigned my enclosure and recently reconnected my spindle for testing, everything was working great at the beginning but I noticed slight unusual sound coming intermittently from the spindle, but didn't look like much. now after last run, whatever I do it doesnt spin at the mechanical side/collet holder. the motor works and I can hear it changing frequency when I change the speed.
I increased the speed further and got a OL error on my VFD which is overload error.
it's the usual chinese 2.2kw spindle 24000RPM but 100mm diameter
any idea?
note: also noticed it drew considerable amount of current at just 9000RPM (meter reached 10A)Last edited by Noplace; 22-01-2016 at 07:52 AM.
22-01-2016 #2
When the spindle is off can you spin the collet/shaft freely by hand? Sounds like the bearings could have bound up?
I know when I have a clogged cutter which stalls in the work the motor coils can still make a sound like they are spinning up, even though the cutter is not moving. Freeing the cutter sorts it out.
Also worth removing the plug on top of the spindle and checking continuity between different pins on the spindle side (windings). Should be a couple of ohms across a winding, not a dead short, for example.
Ok first can you move the collet freely ie does it rotate without power if so then remove the cable from the VFD and check with a Ohm meter what the resistance is between each pair of the three wires going to the spindle.
It sounds to me you might have a bad soldered joint in the plug but check from the VFD end before you remove the plug.
The spindle would make a noise and not spin if one of the wires was disconnected BUT be carful as you could destroy the VFD...Clive
22-01-2016 #4
Yes it freely moves, thanks so much gentlemen your diagnosis is spot on as after replugging the cable it worked normally. Guess I have to inspect and probably remake it heh
Sent from my HTC One_M8 using Tapatalk
Chinese 300W DC spindle - is the spindle shaft grounded?
By HankMcSpank in forum Spindles & Drive MotorsReplies: 44Last Post: 26-11-2016, 07:25 PM -
CONVERSION: Emco F1-p Mill Mach3 convention, Spindle motor problem
By andre13442 in forum Conversion Build LogsReplies: 7Last Post: 14-01-2016, 12:14 PM -
CNC Project - Spinning Wheel Bobbins
By Washout in forum Woodworking Project ShowcaseReplies: 3Last Post: 14-07-2015, 09:25 PM -
TB6560 controller Runs spindle on power up When Mach3 plunges spindle stops
By RoyT in forum Spindles & Drive MotorsReplies: 5Last Post: 29-09-2014, 02:42 PM -
CNC spindle control VFD problem
By djc in forum Motor Drivers & ControllersReplies: 1Last Post: 13-09-2009, 09:26 PM
