22-01-2016 #3
Ok first can you move the collet freely ie does it rotate without power if so then remove the cable from the VFD and check with a Ohm meter what the resistance is between each pair of the three wires going to the spindle.
It sounds to me you might have a bad soldered joint in the plug but check from the VFD end before you remove the plug.
The spindle would make a noise and not spin if one of the wires was disconnected BUT be carful as you could destroy the VFD...Clive
Chinese 300W DC spindle - is the spindle shaft grounded?
By HankMcSpank in forum Spindles & Drive MotorsReplies: 44Last Post: 26-11-2016, 07:25 PM -
CONVERSION: Emco F1-p Mill Mach3 convention, Spindle motor problem
By andre13442 in forum Conversion Build LogsReplies: 7Last Post: 14-01-2016, 12:14 PM -
CNC Project - Spinning Wheel Bobbins
By Washout in forum Woodworking Project ShowcaseReplies: 3Last Post: 14-07-2015, 09:25 PM -
TB6560 controller Runs spindle on power up When Mach3 plunges spindle stops
By RoyT in forum Spindles & Drive MotorsReplies: 5Last Post: 29-09-2014, 02:42 PM -
CNC spindle control VFD problem
By djc in forum Motor Drivers & ControllersReplies: 1Last Post: 13-09-2009, 09:26 PM
