    thanks :) If I can do what is done in this video then I'll be a happy bunny!
    Bearing in mind this is the aluminium plate belt drive version with a 1.5kw spindle and weaker motors. I'm building with rack and pinion drive, steel plates, steel reinforced beam and stronger motors :)
    That's fine if you are happy with 0.5mm DOC as you can see they say only use a 3.2mm EM at .5mtr/min to cut that ali you should be able to do it in one pass. I am only saying this because for £1500 - £1800 you could build a machine that could cut ali properly at a decent feed rate and DOC.
    tell me more :)
  1. Cnc x6-1500-lpt
    By deannos in forum Machine Discussion
    Last Post: 20-09-2014, 11:33 AM
  2. Chinese X6-1500 vs German High-Z S-720
    By Kenxtu in forum Chinese Machines
    Last Post: 23-01-2014, 01:29 PM
  3. eBay: 1500 x 1000 router any use ?
    By EddyCurrent in forum Items On eBay UK
    Last Post: 24-12-2013, 12:18 PM
  4. Replies: 0
  5. Best cnc mill for under £1500-£2000
    By xchipx in forum Milling Machines, Builds & Conversions
    Last Post: 05-03-2009, 08:42 PM
