    I am sure JAZCNC will chime in with some sense.
    You'll not get much sense out of me. . . . But I'll chime in all the same.!!
    Like been said and you probably know your setup is all wrong. Now without knowing the rest of the machine setup, ie: Gantry size Mass, linear motion setup etc then it's difficult to be exact on what to recommend but a good all round setup for Medium Mass machines is this below.
    EM806 or AM882 Drives with 60-70Vdc Like Dodgygeeza suggests are great. Now with your motors being 4 wire then I suspect they will be high inductance and probably series Wound. This will restrict the Torque and speed you'll get at higher feeds. It's also be why you are getting stalling motors with only 24Vdc.
    Series wound motors provide more torque at low speeds but quickly run out as the speed rises so require very high voltage to get any usable speed from them.
    For this reason on machines like Plasma or routers where often cutting or traveling at higher feeds you'll want motors wired parallel which gives more torque higher up the speed curve.
    So I suggest you change the Motors has well for Low inductance 8 wire motors that can be wired in parallel.
    EM/AM drives with 65-70Vdc with 4Nm Nema 23 parallel wound motors give a good setup for meduim sized machine. Again this does however need to balanced against the Linear motoion set up and Mass etc which will need to be considered before deciding on exactly what is best.
    One thing is clear thou what you have now isn't very good.!
  2. The Following User Says Thank You to JAZZCNC For This Useful Post:
  3. #2
    Thanks all for your above replies, particularly JAZCNC - I love the last line, covers it all in a nutshell!
    For now, I have just reduced the rapid speed between cuts, but I intend to retrofit the ctl box when I get a chance. Bearing in mind new PSU, and drivers, I may as well get a new breakout board too and simply build an entire new ctl box which I can swap in when ready. That then gives me a spare (old one) to swap in in emergency.
    I will consider the new motors, but will that not involve rewiring the whole machine for the 8 wire setup? (not a big problem, but more downtime and then reduced compatibility with the old "spare" ctl box).
    General linear motion setup on X and Y axis is a stationary length of (approx 10mm) timing belt down the axis with a pair of idler pullys around the motor to give the drive gear a good wrap around (180 degrees). Drive gear is approx 30mm diameter - I dont have the tooth counts to hand at the moment. Z axis is simply a leadscrew - again dont have the pitch to hand at the moment.
    Its a shame the manufacturer has underspeced the ctl box, cos the actual table is built like the proverbial brick outhouse......
    Quote Originally Posted by lockyg View Post
    No still only needs 4 wires. Motors are 8 wires but phases are wired so only use 4 wires.
  5. #4
    Lives in Marple Stockport, United Kingdom. Last Activity: 14 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,345. Received thanks 618 times, giving thanks to others 87 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    The eight wire motors will be joined up making 4 wires at the motor so no prob with the wiring being changed.
    edit Dean as usual beat me to it
  6. #5
    Ok, thanks - makes sense. Come to think of it, I have a pair of these 8 wire motors in the cupboard from way back when I was intending on building my own machine, before I bought what I currently have. Just need two more on the shopping list!
  7. #6
    Any suggestions for a decent off the shelf 60 or 70vdc supply?
  8. #7
    If you don't want to build one yourself then you won't go far wrong with this. http://zappautomation.clickforward.c...er-supply.html
  1. How do I wire a stepper driver to a stepper motor?
    By swood1 in forum Stepper & Servo Motors
    Last Post: 21-09-2014, 05:40 PM
  2. TB6600HG Stepper Motor Driver
    By stevep in forum Motor Drivers & Controllers
    Last Post: 26-05-2014, 09:33 PM
  3. Replies: 1
  4. Recommend a superior stepper motor driver IC to you.
    By lihaijiang in forum Motor Drivers & Controllers
    Last Post: 16-12-2011, 09:11 AM
  5. Stepper Motor Driver v2.3 2A $20 !!!
    By Lee Roberts in forum Motor Drivers & Controllers
    Last Post: 17-05-2009, 10:57 PM
