  1. 24V, 1.5A TA8435 based - is this worth looking at? I need a 3-axis cheap driver quickly...
    http://www.cqout.com/item.asp?id=4641898#bid
    Item Location : China
    Seller Location: United Kingdom
    John S -
  3. Will be ok for small 23 fram or 17 frame motors, but i cant comment on the quality.
    Quote Originally Posted by Gary View Post
    Yeaaaaa you can, cmon dont be shy !
    Same board, £48.50 to your door here...
    http://cgi.ebay.co.uk/Great-4-Axis-C...3A1%7C294%3A50
    Quite a timely post you made...I now need another driver board for "The McSpank Coil winder MKII" (using two steppers vs one stepper + DC cooling fan!) I've just managed to debug a 'half finished' (& only part working) Mach3 coil winder screenset, which seems to suit my needs perfectly...
    As it goes, I only need two axis, therefore I can cut the driver board in half & sell you the other two!!! :heehee:
    BTW: What is that 'marketplace' where you found this driver board originally? (I've never come across it before & used to think I was internet savvy!)
  1. Replies: 12
    Last Post: 25-05-2013, 12:41 AM
  2. RFQ: Z axis and y axis carriage
    By D-man in forum Projects, Jobs & Requests
    Last Post: 08-04-2013, 10:06 AM
  3. NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis Milling
    By LoveLearn in forum New Member Introductions
    Last Post: 25-01-2012, 08:46 PM
  4. Y axis is making X axis stall...!!
    By fasteddy in forum Machine Discussion
    Last Post: 24-10-2011, 12:19 PM
  5. Precision metal processing (3 axis, 5 axis, 7 axis) OEM
    By 7AxisCNC in forum Manufacturer News
    Last Post: 17-05-2011, 02:04 PM
