    Hi Rob
    Yes I have seen those guitars - they're really nice.
    That Harpejji looks interesting and looks to be more 2D than a Fender design so should be doable if you can find a design/blueprint somewhere.
    Chris
    The Harpejji board should be simple on a CNC router, it is just a matter of getting the fret distances right. The formula is something like 1/17 of the remaining distance to the bridge (but I would check it out properly). Electronics are more of a problem, I think you will need a sustain circuit for each string and that, in turn, means individual pick-up coils. The Chapman Stick works on a similar principle.
    Rob
    Yes makes sense - there's a couple of scale length/fret calculators out there (Stewmac and Manchester Guitar Tech iirc have them).
    I must look into Sustainers as well at some point - I'm guessing they are similar to my beloved e-bow?
    I've always fancied having a go on a Chapman Stick and didn't realise they use a separate pickup coil per string. That's very similar to the Gittler, which is another concept I've had in mind to incorporate into a guitar design.....so many ideas...so little time :)
    If you want to trigger MIDI you need separate coils like on the Shadow SH35. Roland do a similar pick-up, but I can't remember the model number. Otherwise I suppose you can get away with standard guitar pick-ups.
    My experience of MIDI guitar was a little fraught, to say the least, and I have the Shadow kit sitting on a shelf doing nothing for a number of years.
    Rob
    Hi all,
    Some CNC for the Jaguars whilst I wait for the lacquer to harden:
    Part 15a - CAD/CAM
    Part 15b - Machining:
    Hi all,
    Latest video in the Jaguar saga is up, but no CNC this time:
    So by way of compensation here's another scratchplate machining video and CAD/CAM walkthrough from another guitar project I'm getting to the end of:
    Fusion 360 CAD/CAM:
    Machining:
  1. Guitar Hero Meets, T-Slotted Profiles !!!
    By Lee Roberts in forum General Discussion
    Last Post: 24-04-2019, 12:20 AM
  2. NEW MEMBER: Newbie seeking CNC info for guitar building
    By rusty999 in forum New Member Introductions
    Last Post: 15-01-2016, 02:26 PM
  3. FOR SALE: CNC project
    By amxen in forum Items For Sale
    Last Post: 20-12-2015, 09:19 PM
  4. New project - Aluminium Guitar Nut Height Gauge
    By Washout in forum Metalwork Project Showcase
    Last Post: 08-10-2015, 10:04 AM
  5. NEW MEMBER: Back after a little rest
    By bogstandard in forum New Member Introductions
    Last Post: 27-02-2015, 07:12 PM
