25-01-2016 #1
Hi Everyone,
Rather than clogging up the excellent Inspiration thread, I'll start a thread to show my progress on making a Fender Jaguar guitar on my CNC machine (or at least as far as that is possible).
So here's the latest video, carving out the main neck body from maple and a following one, which whilst showing me hand making some body templates shows the results of the neck carving on the machine:
The next video in this series will show the fingerboard, but I have many hours of video to edit so won't be until later this week.My CNC Projects: https://www.youtube.com/imadethisoncnc
25-01-2016 #2
Watched Part 4 earlier today. Excellent work - I take it you play? Looking forward to seeing it plugged in..!
Wal.
25-01-2016 #3
Thanks Wal,
Yes, I've had a guitar addiction for many years, with occasional Bass, Mandolin, Keyboards and woeful attempts at drumming. I've seen your playing on your channel and most impressed - makes me miss the band thing (but not the hauling kit about part).
Oh and thanks for the heads up on the 0.5mm cutter - made me recheck my toolpaths and I had to raise the bottom of the pocket heights by 0.5mm to avoid the taper part of the shank from cutting too deeply into the fret slots. I'll use a fretting saw to deepen the slots if needed.My CNC Projects: https://www.youtube.com/imadethisoncnc
25-01-2016 #4
Hehe, same here. 11 basses at last count...
Got into the CNC thing through wanting to build my own - so far I've built a machine to help me build the bigger machine...
Glad to hear that the heads up on the 0.5 cutter may have saved you a bit of headache.
Wal.
Wal.
25-01-2016 #5
One evening I'm going to sit down and watch these all back to back Chris and make some notes!!! I want to make a guitar (or two....) with my machine starting off with something simple like a Tele and then moving onto an Explorer or V.....
26-01-2016 #6
Hi Neil,
Funnily enough I have in mind a telecaster myself once the two/three guitars I have on the go are finished. The version I have in mind will have front and back binding, a neck humbucker, phase switch and pre-amp i.e. the Andy Summers model without the $10,000 price tag (if Fender made any more that is). Even though I have a US Standard Tele (circa 95) it doesn't have the tonal variations to get Andy's sound and as I finally nailed the Message in a Bottle sound using an EHX Electric Mistress I need the boost as that flanger pedal cuts the volume when activated.
Ooops apologies gone all guitar nerd on the forum... ;)My CNC Projects: https://www.youtube.com/imadethisoncnc
26-01-2016 #7
I was playing a Tele on the weekend in Reidys in Blackburn which had two humbuckers both coil tapped and loved the playability of it and the different tones you could get....going to look for plans this weekend!
It seems there is a language problem here I must try Google translate.
26-01-2016 #9
01-02-2016 #10
More progress - this time the fingerboard (cue foreign guitar geek dialects again ;) )
The Following User Says Thank You to Washout For This Useful Post:
Guitar Hero Meets, T-Slotted Profiles !!!
By Lee Roberts in forum General DiscussionReplies: 4Last Post: 24-04-2019, 12:20 AM -
NEW MEMBER: Newbie seeking CNC info for guitar building
By rusty999 in forum New Member IntroductionsReplies: 4Last Post: 15-01-2016, 02:26 PM -
FOR SALE: CNC project
By amxen in forum Items For SaleReplies: 1Last Post: 20-12-2015, 09:19 PM -
New project - Aluminium Guitar Nut Height Gauge
By Washout in forum Metalwork Project ShowcaseReplies: 11Last Post: 08-10-2015, 10:04 AM -
NEW MEMBER: Back after a little rest
By bogstandard in forum New Member IntroductionsReplies: 3Last Post: 27-02-2015, 07:12 PM
