Thread: Power Supplies
25-01-2016 #1
I bought a controller/motor/driver/2xPower supplies set from ebay last week.. it's still on its way but I have realised that the kit I chose didn't have the power supplies in. Annoying! I thought it was a bargain :) It's too late to cancel so I need to sort out the power supply.
The kit I intended to get came with:
- 4 pcs Nema 23 stepper motor with 425 oz.in 23HS9442
- 4 pcs stepper motor driver DM542A, peak 4.2A, 128 micsteps, replacing M542
- 2 pcs Power supply 350Watts (36VDC/9.7A)
- 1 pc Breakout board & 1 pc Parallel cable
Does anyone have any recommendation for what I should get? Just replace with the same or would I benefit from a higher powered unit - or 2 higher powered units even?
Budget end of the spectrum by the way :)
25-01-2016 #2
You could make your own powersupply. I am sure I saw the diagrams on here somewhere. 36V is a good place to start but you could push the Nema 23s to 48V if needed.
see: http://www.mycncuk.com/threads/9333-...-Diagram-checkhttps://emvioeng.com
25-01-2016 #3
I'll be honest - building a power supply doesn't do it for me :) I'm just going to go for an off the shelf solution.
Is there a good reason that 2 power supplies were part of the kit?
25-01-2016 #4
yes, they are both 350W which would limit the current that the total of 4 motors would be able to draw at any given time.
You could probably buy the same powersupplies that were in the kit locally too.https://emvioeng.com
25-01-2016 #5
That was my suspicion but I thought a better quality higher rated PSU might have sufficed as opposed to 2xcheaper units
25-01-2016 #6
OK from what I can gather I need around 11.5A from the power supply. I have a choice of 2x 350w 7.3A or 1 x 600w 12.5A.. What is my best option?
26-01-2016 #7
Which option works out cheaper?
26-01-2016 #8
£64 and £66 respectively
26-01-2016 #9
2 times the 350w would be my choice then ;)
26-01-2016 #10
Cheers! some things can look too obvious when you don't know :)
FOR SALE: 3x lambda power supplies
By dazza in forum Items For SaleReplies: 0Last Post: 13-02-2015, 04:33 PM -
Power Supplies
By GTJim in forum General ElectronicsReplies: 5Last Post: 26-04-2013, 04:06 PM -
Minimal-cost Power Supply Strategy - Repurpose Laptop Power Supplies
By LoveLearn in forum General ElectronicsReplies: 0Last Post: 25-01-2012, 09:29 PM -
FOR SALE: Power supplies
By Jimmybristol in forum Items For SaleReplies: 2Last Post: 21-05-2011, 07:37 PM -
FOR SALE: 3 x 48V 12.5A Power supplies for sale
By Jimmybristol in forum Items For SaleReplies: 7Last Post: 25-03-2011, 07:18 PM
