    I ordered the right amount from Chai but used a BK12 bearing on my Z axis instead of the intended FF type I ordered so now I'm a BK12 short. Just need the one with nut.
    Not having much luck with this one ?
    I'll have a look and see what i've got. I may have the block but not the nut.?
    Read your post yesterday and ignored it as I don't use these... but just remembered that I do have one which I fully intend on never using. Not sure if I pilfered the bearings from it or not. Assuming it's complete you can have it for whatever the bearings cost, as that's the only bit which is useful to me.
    I can easily post it on Saturday, when I go home, or ask my Mum to post it but that might be a bit risky!
    Thanks Jonathan, I would only want it if complete, let's see what Dean or someone else comes up with and I'll know what's what before the weekend.
    You've got a pm Eddy. .Me
    .Me
  7. The Following User Says Thank You to Lee Roberts For This Useful Post:
  8. #7
    Thanks Dean and Jonathan but Lee has come up with a most excellent solution.
  9. #8
    After finding 2x 6001 bearings in my BF12 block it may pay to check what you have in your block.
  1. BK12 end float?
    By birchy in forum Lead Screws, Nuts & Supports
    Last Post: 20-07-2013, 02:28 AM
  2. BK12 Hole Spacing Dimensions On Top
    By Hobgoblin in forum Lead Screws, Nuts & Supports
    Last Post: 21-09-2012, 10:31 PM
  3. Understanding the bearing block
    By Rogue in forum Rails, Guideways & Bearings
    Last Post: 28-08-2011, 03:14 PM
  4. BK12 & BF12 bearings
    By mlmSolutions in forum Lead Screws, Nuts & Supports
    Last Post: 04-01-2011, 11:16 AM
  5. NEW MEMBER: New Kid on the block
    By 25ncjimmy in forum New Member Introductions
    Last Post: 24-07-2009, 06:01 PM
