    I'm in the process of designing a prototype machine that has a few large say 2-3m shafts @ 25mm-32mm diameter. I do not have a lathe big enough to machine the ends of the shaft to fit bearings and taper locks bushing. Is it possible to buy a stock piece of steel that is ground or turned to take a standard size of bearing. What would you call this stock and where would you buy it?
    CNC routing and prototyping services www.cncscotland.co.uk
    ADD ME ON FACEBOOKS
    Quote Originally Posted by gavztheouch View Post
    Could you not have it machined at the local engineers machine shop 32mm is not that big for an engineering company to deal with.
    Lives in Plymouth, United Kingdom. Last Activity: 2 Weeks Ago Has a total post count of 1,749. Received thanks 299 times, giving thanks to others 11 times.
    If you do a search for ground bar stock you will find some suppliers. It seems to be available up to 3m lengths fairly easily and a range of diameters. You might be able to find a local supplier.
    Zapp have ground shaft and i think they will be able to machine the ends for you.
    this is a link.
    http://www.zappautomation.co.uk/mech...-rail-385.html
    Stock material for shafts is called shafting, google, for instance, 25mm shafting
    - Nick
    Perhaps you could get round the small lathe problem by machining it in separate pieces? Machine the ends you require on something shorter, then join it to the steel bar (e.g. press fit, key, etc)? Unless the runout required is really strict (seems unlikely due to the length), that should be fine...
    Or just find someone with a not tiny lathe. Mine has a 38mm spindle bore. Not sure about 3m long though - there may be a wall in the way!
  1. Metal Stock Purchasing UK
    By paul_m in forum Metalwork Discussion
    Last Post: 25-05-2015, 04:42 PM
  2. RFQ: RFQ: Keyslot milling in alu round stock.
    By Saracen in forum Projects, Jobs & Requests
    Last Post: 05-09-2013, 09:42 AM
  3. Method for holding Stock
    By Chaz in forum Machine Discussion
    Last Post: 24-06-2013, 11:41 AM
  4. Bought a laser, now there's a thing
    By Robin Hewitt in forum Laser Machines & Building
    Last Post: 25-02-2013, 07:20 AM
  5. Simple Solution- Drive 1" Ball Screw Shaft with NEMA-23-Size Stepper Motor Shaft
    By LoveLearn in forum Gantry/Router Machines & Building
    Last Post: 08-02-2012, 01:52 AM
