Stock material for shafts is called shafting, google, for instance, 25mm shafting
- Nick
31-01-2016 #2
Perhaps you could get round the small lathe problem by machining it in separate pieces? Machine the ends you require on something shorter, then join it to the steel bar (e.g. press fit, key, etc)? Unless the runout required is really strict (seems unlikely due to the length), that should be fine...
Or just find someone with a not tiny lathe. Mine has a 38mm spindle bore. Not sure about 3m long though - there may be a wall in the way!
31-01-2016 #3Drill a hole in the wall of your workshop standard practise.Not sure about 3m long though - there may be a wall in the way!..Clive
31-01-2016 #4
Can you do it the way they used to in industry where everything fits on the shaft rather than having to machine the shaft to accept something?
If you buy shafting rather than round bar the OD will not require machining down to accept bearings.
Taper lock couplings could provide a way to securely fit ends on a length of stock shafting with pillow blocks (if and where required) to support the free length.
Everyone's poking around in the dark because there isn't enough requirement info in the question for a definitive answer,
Regards,
NickLast edited by magicniner; 31-01-2016 at 11:37 AM.
Metal Stock Purchasing UK
By paul_m in forum Metalwork DiscussionReplies: 7Last Post: 25-05-2015, 04:42 PM -
RFQ: RFQ: Keyslot milling in alu round stock.
By Saracen in forum Projects, Jobs & RequestsReplies: 2Last Post: 05-09-2013, 09:42 AM -
Method for holding Stock
By Chaz in forum Machine DiscussionReplies: 4Last Post: 24-06-2013, 11:41 AM -
Bought a laser, now there's a thing
By Robin Hewitt in forum Laser Machines & BuildingReplies: 26Last Post: 25-02-2013, 07:20 AM -
Simple Solution- Drive 1" Ball Screw Shaft with NEMA-23-Size Stepper Motor Shaft
By LoveLearn in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 08-02-2012, 01:52 AM
