03-02-2016 #4
Have you build anything before? I don think so or it was not that big
So let me help you a bit:
-You miss some basic understanding that Box section is stronger than U profile. Eliminate from your drawing any U section. Its ideal use is for table bed.
-Diagonal braces are more difficult to cut, almost impossible to weld and do less job than bigger box section in simple order-You have drawn 1.2 ton of a machine and i could achieve stronger machine for half the weight.
-These bolts for leveling the rails are mistake. Eliminate them. Either do separate portal with both sides and separate table in the middle / what i would do for stone/ or lay rails directly on table sides. Raised or not.
So basically my advise is to do separate gantry and rails and sides, plus separate table in the middle. As the HD plasma systems do it. Or read my second build from my signature, as this is the other option. My machine will happily answer all of your criteria. Plus will save you a ton of money on the build if you follow what i have done as gantry and especially for the Z. You will note that i have extremely heavy duty bed that lies directly bolted on frame and makes my machine extremely strong
Now separate or not will depend on how many water will flow around, how heavy the stones, how you will load them, if from time to time ...
Hope that helps.Last edited by Boyan Silyavski; 03-02-2016 at 06:22 PM.
The Following User Says Thank You to Boyan Silyavski For This Useful Post:
BUILD LOG: First Build-Steel Gantry CNC - Comments on design wanted
By olaff in forum DIY Router Build LogsReplies: 13Last Post: 06-12-2015, 08:34 PM -
Need help, buy or build to cut steel, stainless steel, titanium etc
By fatguyslim in forum Machine DiscussionReplies: 41Last Post: 08-02-2014, 11:37 PM -
BUILD LOG: Steel/Aluminium design/build, sorta smallish, cuts ali hopefully
By mart154 in forum DIY Router Build LogsReplies: 27Last Post: 19-09-2013, 05:48 PM -
BUILD LOG: Vertical fixed gantry. Design & build. (Steel/epoxy)
By Greeny in forum DIY Router Build LogsReplies: 8Last Post: 19-08-2013, 08:26 PM
