Thread: Suitable Wood CNC mills
03-02-2016 #8
Hi Andy
I think the reason you're maybe not getting the feedback you require here is that the CNC market (especially in the UK) is the same as the PC market in say the late 80's/early 90's.
You have a few cheap machines (£1000 ish 6040's etc.) which are compromised as detailed above and then there are some UK builder/retailers who are charging £3,000-5,000, which frankly in some cases are not much better or at least have cut corners here and there to maximise margins. Some of the inflation is due to the supplier providing some kind of onsite or remote support package, which if you're running a business maybe worth it, but you will eventually learn the machine and likely not need this or may not need it at all depending on knowledge level.
If you definitely only want to cut wood then a machine with supported rails will likely suffice depending on how often you intend to use the machine and the depths you want to cut to (unsupported rails are a definite "no-no" for anything apart from light engraving or very shallow cuts). Even then and certainly if the machine is going to be in constant "commercial" use (and if I was building a second machine even as a hobbyist) I would always go for linear profiled rails, ballscrews and a 2.2KW spindle and electronics that use an ethernet rather than the parallel port. Unfortunately I'm not aware of any router manufacturers in the UK that offer this kind of machine and they would certainly uplift the £3-5K price tag, even though I estimate a machine of this sort would cost somewhere around £2000 to build, although guys who have built a machine to this rough spec would be able to advise better.
If you have the time then "self build" is a far more cost effective solution and is what most here do, but you will have to do your research into the various build logs to get ideas.
I hope that helps, but the "take away" is be careful if going retail and if you do find something that looks suitable - post a link or pic and the guys here will gladly advise on what to look for.My CNC Projects: https://www.youtube.com/imadethisoncnc
Large PC case suitable for housing MOBO & CNC equipment.
By lateAtNight in forum Classified Ads, Buy, Sell & SwapReplies: 1Last Post: 18-06-2015, 10:26 PM -
RFQ: Wood CNC routing service (wood Letters)
By coujin in forum Projects, Jobs & RequestsReplies: 0Last Post: 16-02-2015, 03:35 PM -
FOR SALE: End mills and Ball mills for sale......
By Jimmybristol in forum Items For SaleReplies: 2Last Post: 16-02-2011, 12:37 AM -
Suitable for a cnc mill ?
By j4son in forum Milling Machines, Builds & ConversionsReplies: 1Last Post: 12-01-2010, 08:58 PM -
PWM Fan control, is this suitable?
By Smiler in forum General ElectronicsReplies: 1Last Post: 25-03-2009, 02:52 PM
