    The Chinese water spindle is way better than the Kress, which is not really made for that job. Its like comparing Ferrari to a tractor
    I was leaning towards the Chinese spindle, since i saw a comparison, and it is a lot quieter.
    As far as I know Ferrari also made tractors, and the Proxxon I had was not made for the job, but it worked for the last few years. But as I said, I will most likely go with a Chinese spindle.
    Poslano z mojega ONE A2003 z uporabo Tapatalk
    Quote Originally Posted by Zynch175 View Post
    Think you'll find that was Lamborghini.!!. . . But Boyan is correct Kress are toys in comparison.
    So I found some local guys doing a group buy, and I got in, so I ordered a 1,5kW spindle, since the 2,2kW are quite a bit over my budget.
    Chaz's Avatar
    Lives in Ickenham, West London, United Kingdom. Last Activity: 6 Days Ago Has a total post count of 1,657. Received thanks 115 times, giving thanks to others 71 times.
    I had a Kress. Noisy as hell. Go for a smaller Chinese Watercooled spindle if you can.
    And I wouldn't worry about going for the smaller spindle. I doubt that many home-built machines can fully load the bigger spindle and the main reason for choosing the larger size is they usually take ER20 collets which allow up to 1/2" cutter shanks.
    Chaz's Avatar
    Indeed. The Kress is only rated at 1050 Watts. I think it will smoke before it delivers that type of output.
    I went for the 1.5kW one, since the group buy has the 1.5kW or 2.2kW. And I decided that the new spindle is going on the new machine, that is in the process of designing (about 1000x1500 in size). It is going to be a modified frame of an embroidery machine, and the stepper motors and their drivers will also come from the machine. Once I get some drawings together I will post it to get an opinion on the design.
    I've got a 2.2kw WC spindle coming for a new build, what size cutter could these handle in aluminium??
    I have read that torque drops badly at lower speeds but what is the usable range???
    Chaz's Avatar
    Typically 12 - 24K. Size of cutter all depends on width and depth of cut.
    http://zero-divide.net/?page=fswizard get used to using this, it also tells you how much power you need.
    The usable range is between 5000 and 24000 rpm if the VFD is setup properly. But yes torque does drop at lower speeds so does have limitations.
    You can use the full cutter size range upto 13mm in aluminium but it will affect DOC and Feedrate. I cut lots of aluminium and find 8mm with 3 flutes is nice size that allows good DOC and feed rates. If used with trochiodal toolpaths the removal rate is brilliant and shifts large amount of chips.
    My 2 most often used cutters are 8mm 3 flute rougher and 6mm 2 flute spiral flute for finishing. When ever possible I use Trochiodal toolpaths.
  1. Q: Start Kress 1050 with Gecko540?
    By Trulsen in forum Kress Milling Motors
    Last Post: 01-10-2013, 04:50 PM
  2. eBay: Kress 1050 FME-1 Spindle
    By viz in forum Items On eBay UK
    Last Post: 21-08-2013, 04:04 PM
  3. eBay: Kress 1050 FME router
    By rbs in forum Items On eBay UK
    Last Post: 08-05-2012, 12:40 PM
  4. FOR SALE: 4 Axis CNC with Kress 1050 FME & Computer etc
    By miribilist in forum Items For Sale
    Last Post: 26-02-2012, 09:12 PM
  5. collets for a Kress 1050
    By groov in forum Kress Milling Motors
    Last Post: 20-08-2009, 11:54 PM
