19-02-2016 #16
Great, thanks.
Things are simpler on my manual Bridgeport - just throw in a tool, set the speed to the chart and turn the hand wheels at a rate that keeps her happy :) Got a lot to learn - my reason for building a CNC partly.
So i have a g-code file from SheetCam and it was programmed for say a 6mm roughing cut leaving an allowance for finish, do i need to make a second file for the finish cut or do you use the same cutter but just program a final cut for the finish pass??
One job i have in mind has some 3mm holes in it, i would be looking at ramping in with a 2 or 2.5mm tool for them and then do the outside profile with a larger tool maybe - I am lacking knowledge of how you change tool and get back to exactly the right place OR do you use the tool dia offsets in Mach3
As i said, lots to learn;)
Q: Start Kress 1050 with Gecko540?
By Trulsen in forum Kress Milling MotorsReplies: 8Last Post: 01-10-2013, 04:50 PM -
eBay: Kress 1050 FME-1 Spindle
By viz in forum Items On eBay UKReplies: 0Last Post: 21-08-2013, 04:04 PM -
eBay: Kress 1050 FME router
By rbs in forum Items On eBay UKReplies: 12Last Post: 08-05-2012, 12:40 PM -
FOR SALE: 4 Axis CNC with Kress 1050 FME & Computer etc
By miribilist in forum Items For SaleReplies: 6Last Post: 26-02-2012, 09:12 PM -
collets for a Kress 1050
By groov in forum Kress Milling MotorsReplies: 5Last Post: 20-08-2009, 11:54 PM
