19-02-2016 #23
No it's not generally good advise because depends on the type of cut and machine, along with several other factors like cooling etc.
Slot cutting is worst case for most because chip clearence is less so people use less flutes to give more clearence. But if the machine is strong enough and cutting parameters are correct then 3 flute will work just fine and give higher MRR. It's generaly only good advise to those that don't know there machines capabiltys.!
Like wise for finishing or cutting with plenty of chip clearence like profiling then multi flute cutters work great provided the machine can handle the higher feed rates. People go wrong by using multiflute cutters is wrong situations or more often much too low feedrate. If run correctly in right places multiflute cutters give a much better finish.Last edited by JAZZCNC; 19-02-2016 at 10:09 PM.
Q: Start Kress 1050 with Gecko540?
By Trulsen in forum Kress Milling MotorsReplies: 8Last Post: 01-10-2013, 04:50 PM -
eBay: Kress 1050 FME-1 Spindle
By viz in forum Items On eBay UKReplies: 0Last Post: 21-08-2013, 04:04 PM -
eBay: Kress 1050 FME router
By rbs in forum Items On eBay UKReplies: 12Last Post: 08-05-2012, 12:40 PM -
FOR SALE: 4 Axis CNC with Kress 1050 FME & Computer etc
By miribilist in forum Items For SaleReplies: 6Last Post: 26-02-2012, 09:12 PM -
collets for a Kress 1050
By groov in forum Kress Milling MotorsReplies: 5Last Post: 20-08-2009, 11:54 PM
