24-02-2016 #17
I am away at this time but thinking about it I am sure that any 2A cable will do the job ie. just use the lighting flex that is used from the ceiling rose to the lamp holder that can be got from any B&Q or hardware store. I used the cable that was cut off the proxy switches that I used for homing.
Machine couriers,lathe
By dazza in forum Marketplace DiscussionReplies: 9Last Post: 04-04-2017, 05:01 PM -
profiled rail wich preload do you use ZO (light) ? ZA (Medium) for a diy router ?
By pierantoine in forum Rails, Guideways & BearingsReplies: 2Last Post: 01-01-2016, 06:13 PM -
Machine Feet for my lathe
By cncJim in forum Lathes, Lathe Rebuilding & ConversionsReplies: 27Last Post: 01-11-2014, 12:35 AM -
NEW MEMBER: Total Newbie....looking for the light....
By MOCNC in forum New Member IntroductionsReplies: 2Last Post: 01-07-2014, 10:37 PM -
4th Axis running as CNC lathe using milling machine
By Jonathan in forum Milling Machines, Builds & ConversionsReplies: 6Last Post: 21-08-2011, 10:34 AM
