++1. I bought a pair of these on Clive's recommendation - they look good, they're easy to mount and very bright indeed..!
Wal.
23-02-2016 #2
Hi Guys
The LED lights arrived yesterday, just need a little more information please.
I would like to extend the wires coming from the unit with some decent quality cable.
What size do i need ?
the light has 3 core cable red/black/white i assume red is positive and black negative, is the white core an earth ?
what would be the best way to connect the new cable/ solder the new and shrink sleeve or go into the unit and solder to the board.
Thanks in advance
Mike
23-02-2016 #3
23-02-2016 #4
Thanks live
So is red positive & black negative ?
23-02-2016 #5
24-02-2016 #6
Thanks for the recommendation, guys. I was looking for a replacement for the 48V worklight on my lathe. Given that the bulbs are pretty much impossible to find, and the transformer would need replacing anyway (was 415-48 but now running the lathe via an inverter so only 240V available continuously) I ended up looking at the lights from RS and so on at £100-120 or so. Fortunately, I saw this thread before I ordered and ended up with a couple of 10W LED fog lamps. Small, run cold, give out lots of light, and just need a cheap 12V power supply. I went for fog rather than spot to give a slightly more spread beam pattern and something not too bright. I've just tested them on the bench and they look very good indeed for this job. And for just over a tenner, post paid. I'll bolt one of these to the existing worklight arm on the lathe and probably use the other one on the mill.
24-02-2016 #7
I am ordering some wire tonight and waiting for the power supply, but that's only just been shipped due to Chinese New Year delay, looking forward to getting it up & running, went to pick up a lathe for a pal yesterday so will probably be getting him one as well.
nice one Clive
Machine couriers,lathe
By dazza in forum Marketplace DiscussionReplies: 9Last Post: 04-04-2017, 05:01 PM -
profiled rail wich preload do you use ZO (light) ? ZA (Medium) for a diy router ?
By pierantoine in forum Rails, Guideways & BearingsReplies: 2Last Post: 01-01-2016, 06:13 PM -
Machine Feet for my lathe
By cncJim in forum Lathes, Lathe Rebuilding & ConversionsReplies: 27Last Post: 01-11-2014, 12:35 AM -
NEW MEMBER: Total Newbie....looking for the light....
By MOCNC in forum New Member IntroductionsReplies: 2Last Post: 01-07-2014, 10:37 PM -
4th Axis running as CNC lathe using milling machine
By Jonathan in forum Milling Machines, Builds & ConversionsReplies: 6Last Post: 21-08-2011, 10:34 AM
