    Hi
    I want to describe an idea that I had last days.
    As it is very possible to use epoxy level for my machine and I will use a small amount of epoxy ( that will finally go to thrash) for some tests. So I was thinking if it reasonable to make the tests using two aluminum rectangular tubes 80X20 as follows.
    We start with a 6 m long aluminum rectangular tube, cut into two pieces of 3m long each
Name:	straight edge 1.JPG
    We attach the two tubes with 2mm spacers( blue color)
Name:	straight edge spacers 2.JPG
ID:	17497Click image for larger version.
Name:	straight edge spacers.JPG
    At the edges we put two pieces of mdf as at the following pictures also with spacers between the mdf and aluminum profiles
    We put the spacers so that we can cut the epoxy after cure.
    Then we level the tubes, we fill with silicone the 2mm gap that the spacers will make and we pure epoxy.
Name:	straight edge mdf 1.JPG
ID:	17499Click image for larger version.
Name:	straight edge spacers epoxy.JPG
ID:	17501Click image for larger version.
Name:	straight edge spacers epoxy 2.JPG
    After the epoxy get hard, we remove the spacers and we use a hacksaw blade to cut the epoxy
    We now have (or we don’t have ????)two pieces of aluminum profile with a true surface.
Name:	single straight edge 2.JPG
ID:	17503Click image for larger version.
Name:	single straight edge.JPG
    MDF offsets are used to “absorb” the meniscus
    We will need nearly 0.5*6.6*300=990ml of epoxy ( for this length )
    1 X6m long aluminum rectangular tube
    Spacers
    Mdf strips
    Of course somebody could use shorter tubes, even one only tube with mdf stripes left and right or cut the tube (after epoxy cure) to different lengths.
    What is your opinion?
    Does it worth to try?
    I edit the post to make it more clear, ( after i read clives_s question that follows).
    The main purpose of this DIY is to make a straight edge with low cost, instead of buying one that at this length will be out of the question.
    The aluminum tubes that will be produced from the above process WONT be used as adjustable top beams where the rails will rest
    The creative adult, is the child who survived
    Lives in Marple Stockport, United Kingdom. Last Activity: 14 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Then what are you going to do with them? You will end up with two rails that will bend when you move them.
    One of the reasons for using epoxy is so that the rails that are fixed to the frame will be on the same plane.
    Imagine a trough on the top of your rails that you fill with water it will be level in all planes it does not matter if the frame was twisted a little or out of level with the opposite rail.
    O
    I dont want to use them for constucting a machine, but to check the flatness of a machine, just the way i would do with a straight edge
    The use of these rails is to use them as straight edge so that you can chek the flatness of a machine.
    My question is if these aluminum tubes are reliable straight edges?
    Are you thinking of using these to get your rails straight?
    Quote Originally Posted by GTJim View Post
    I already have a 1200mm long straight edge
    It is enough to messusre my machine (1800mm long, 1160mm wide) between left and right sides.
    For the distance of 1800 i will use the same straight edge in parts
    If the above solution is reliable it will make my life easyer about messuring the flatness of 1800mm long rails
    It is just a thought and i ask if somebody has an opinion about this
    I dont think i am the first that has this idea
    For me it sounds logical that it will work, unless i miss something
    Any straight edges above 1200mm that I have seen are very expensive. So I hope your suggestion works as I have yet to come up with a better one.
    Jim
    Hi Don't see much of a problem here, you say width of rails 1160 so your straight edge will span that distance, to ensure the 1800 rail is straight set the master rail onto the grout leveled frame member and lightly clamp both ends, drill and tap the frame for the hole in the centre of the rail, work your way from the centre of the rail to the ends drilling tapping correcting and fixing the rail as you go, you will have a section of rail that can be verified straight with the straight edge, all you have to do is extend the straight edge 200mm each end to set the remaining portions of rail. the second rail can be set using a fixture with carriages set on the master rail and on the one your trying to bring into spec, most find that using the gantry works OK.
    Regarding drilling and tapping you need a couple of jigs that will align in the countersunk holes of your rail, one to align the drill and one to keep the tap vertical.
    Regards
    Mike
  8. The Following User Says Thank You to mekanik For This Useful Post:
  9. #8
    I have had exactly the same idea in my head for a week now :)
    I will try to make my straight edge out of the "bridge" when leveling my long axis.
  10. #9
    The two 3m aluminum tubes one way or another i should had bought them for general measuring use
    Assuming that the extra cost is only the 500ml extra epoxy ( as for the above project will be needed 990ml), i will make a try
    I Know that the result will be disputed
    Of course i will use my straight edge against the epoxy surface to check the result
    Mean while any advice will be welcome.
    Thanks for your participation
  11. #10
    Vagelis Personally I wouldn't waste the time or Money. You have decent length straight edge and using Technique Mekanik suggested will work for checking flatness of 1800 rails.
  1. BUILD LOG: Aluminum profile and alu plate 1500mm x 600mm x 150mm working area, first cnc.
    By pierantoine in forum DIY Router Build Logs
    Last Post: 01-04-2017, 11:33 PM
  2. Low profile, compact work-holding solutions. Advice sought.
    By Wal in forum Tool & Tooling Technology
    Last Post: 26-08-2016, 10:45 PM
  3. Straight sections of box steel
    By gavztheouch in forum Metalwork Discussion
    Last Post: 03-01-2012, 02:37 PM
  4. can't cut straight or even drill straight, so need help
    By deannos in forum Machine Discussion
    Last Post: 02-10-2011, 05:35 PM
  5. Electronic edge finder: how do they work?
    By irving2008 in forum Probing, Digitizing & Scaning
    Last Post: 29-08-2009, 10:25 PM
