07-02-2016 #9
The two 3m aluminum tubes one way or another i should had bought them for general measuring use
Assuming that the extra cost is only the 500ml extra epoxy ( as for the above project will be needed 990ml), i will make a try
I Know that the result will be disputed
Of course i will use my straight edge against the epoxy surface to check the result
Mean while any advice will be welcome.
Thanks for your participationThe creative adult, is the child who survived
BUILD LOG: Aluminum profile and alu plate 1500mm x 600mm x 150mm working area, first cnc.
By pierantoine in forum DIY Router Build LogsReplies: 36Last Post: 01-04-2017, 11:33 PM -
Low profile, compact work-holding solutions. Advice sought.
By Wal in forum Tool & Tooling TechnologyReplies: 23Last Post: 26-08-2016, 10:45 PM -
Straight sections of box steel
By gavztheouch in forum Metalwork DiscussionReplies: 2Last Post: 03-01-2012, 02:37 PM -
can't cut straight or even drill straight, so need help
By deannos in forum Machine DiscussionReplies: 2Last Post: 02-10-2011, 05:35 PM -
Electronic edge finder: how do they work?
By irving2008 in forum Probing, Digitizing & ScaningReplies: 14Last Post: 29-08-2009, 10:25 PM
